Tpms (no rke)
Old Jan 23, 2009 | 10:37 PM
rforsland's Avatar
If you have a good tire center in your area, see if they have a copy of the Mitchell1 TPMS manual. It supposedly has the reset/relearn procedures for every car manufactured with TPMS. It may shed some light if your vehicle truly has no RKE capabilities.
Old Jan 23, 2009 | 10:52 PM
Thanks, I will give that a try.
Old Jan 24, 2009 | 11:36 AM
ChevyMgr's Avatar
Originally Posted by donbrew
I have a 2008 HHR LT (fleet/rental); That means among other things it DOES NOT have RKE or remote start, there IS NO remote receiver module, I have had it checked at the local dealer, NO REMOTE RECEIVER.
The question is: How does one rotate the tires and then re-match the TPMS to the wheels.
Your vehicle does have a RCDLR (Remote Control Door Lock Receiver). The 2008 fleet HHRs must have the RCDLR because of the government mandated requirement that all '08s have TPM (Tire Pressure Monitoring). The receiver is the only way the TPM sensors can talk to the BCM (Body Control Module).
But just like a base model pickup truck it does not have the "RKE/Remote Start Package". I have never looked at the BCM options to see if at least RKE could be turned on with the Tech II scanner, but I know the remote start is not simply turned on for sure.
Your TPM sensors are programmed the same way as all others, either using the owners manual instructions or the Kent Moore tool supplied to dealers by GM.
You can get more questions answered here concerning the TPM system:
https://www.chevyhhr.net/forums/tires-wheels-49/tire-pressure-monitoring-faqs-20882/
Old Jan 24, 2009 | 12:56 PM
TomsHHR's Avatar
Over 20 rentals from 2006-2008 of the HHRs I have driven have all had a FOB in the HHR and all but one worked and I woke up the motel with that one...
Thats How I did my "Find My HHR Game"
Old Jan 25, 2009 | 12:53 PM
Thanks ChevyMGR.
So since there is no RKE I MUST go to a dealer (who knows about and has the special tool) to have the TPMS matched? Or, maybe find a tire shop that has the special tool?
That seems like GM is really trying to pull something
Old Jan 25, 2009 | 04:22 PM
Maven's Avatar
Thanks ChevyMGR.
You misread.
ALL HHRs with TPMS have an RCDLR. You perform the relearn procedure same way as a higher model, you just have to use the DIC to engage learn mode.
Old Jan 25, 2009 | 04:23 PM
Maven's Avatar
no special tools are required
Old Jan 26, 2009 | 10:40 AM
Okay, then I am back to the original Question. How do I use the DIC to enter learning mode? The Owner's Manual only details pushing lock and unlock on the fob at the same time, I do not have any option in the DIC pertaining to the TPMS. Have I missed something?
Thanks
Old Jan 27, 2009 | 09:16 PM
ChevyMgr's Avatar
Thanks
Most likely you do have the ability to have RKE. All the dealer has to do is plug their scanner in and see if it has the programming capabilities to set up a fob, which I think it does.
To get into personalization you press and hold the bottom two left hand buttons on the steering wheel for 2 seconds. I don't think you will have a TPM set up in there, but I could be wrong since I haven't looked on a fleet 08 HHR.
Old Jan 28, 2009 | 05:20 PM
Thanks ChevyMgr,
BUT, see post #7 in this thread. The dealership I bought from tried the Tech II Scanner. if that's the right name for the magic programming box. He said that the scanner told him there was no receiver, so he went looking and could not find one, he did verify that the fob was the correct part number for the year and model.
I have been into the personalization menu and there is no tire pressure option. I also got that advice from dealership #3 in my quest.
I am beginning to think that the vehicle is a slap together of parts, regardless of what CARFAX says.
The vehicle is a work machine and I really cannot afford to be off the road at dealerships hoping to find a tech that that was paying attention that day in school.
Any suggestion on how to find a Mr. Goodwrench who knows this particular tidbit, or can document that the computer/dashboard has been doctored. Proof of doctoring could be actionable.
Also I did PM you the VIN to which you replied no RKE.
Willing to Believe
Don
