TPMS, something happened
Old Jul 20, 2011 | 11:04 AM
Lucky's Avatar
Originally Posted by Stan M
My 08 SS just exhibited this TPMS problem today. The RR sensor was intermittently reporting zero pressure. This vehicle has 55,000 on the odometer. Before logging on to the HHR Net, I did a Google search, which pointed to an earlier thread in which ChevMgr mentioned a TSB, something to do with reprogramming the system.
https://www.chevyhhr.net/forums/problems-service-repairs-42/tire-pressure-monitor-problems-14381/
I had the same problem with my 08 but mine was on the left rear. I had to replace the sensor and it has corrected the problem. I was able to change the sensor without removing the tire completely from the rim but it was a pain. when I have to replace another one it will go to the local tire shop.
Old Jul 22, 2011 | 06:47 AM
kwboydston's Avatar
I have an 08 replaced the TPMS sensors whenI put new wheels on I went with a schrader aluminum instead of the rubber type
http://www.alltiresupply.com/p-SB-20158.html
Old Jul 25, 2011 | 10:45 AM
Jeda13's Avatar
Assuming you have to take the tire of the rim when you put the Schrader TPMS in? My RR just failed at 23K but I'm out of warrenty (bought it 3 years ago this July) I need new tires by fall, I'll order 4 of these (HHR Specific) and have them installed over the factory.
This is a stupid problem and though I know the general non-enthusiast public is somehow safer by this rule, the government should mandate that this be a lifetime warrenty. STUPID chinese made rubber crap. After this car, I'm done with GM.
Can I just drive this until I replace the tires or is it going to alert Big Brother and disable my car?
JIm
lasater
Jan 30, 2016 09:24 AM
badassbowtie
Nov 22, 2014 11:27 AM
BlackknighT
Aug 19, 2011 07:15 PM
MWG2
Nov 26, 2008 10:26 PM
Cokeybill
Jun 23, 2008 11:28 AM
