Transmission
Old Aug 11, 2019 | 07:33 PM
Jessica Rogers's Avatar
Transmission
Have a 2008 chevy hhr changed tranny filter and fluid now it won't shift to drive. Are there any other years compatible to swap
Old Aug 11, 2019 | 07:49 PM
Welcome to the site, check the shifter cable position.
How many quarts of transmission fluid did you put in.
what fluid did you use .
2006 thru 2011 4T45 automatic, interchange
Old Aug 11, 2019 | 07:52 PM
All years plus a lot of other models. It would probably be smart to make sure what the prob is. Just changing fluid and filter shouldn't cause that.
Old Aug 11, 2019 | 11:19 PM
It was slipping just a lil so we thought changing the filter and fluid would help instead after we did it stopped shifting to drive
Old Aug 11, 2019 | 11:23 PM
So a 2007 tranny will work
Old Aug 12, 2019 | 04:19 AM
So my boyfriend was looking and says he Put the wrong transmission fluid in! Is this possibly the reason it won't shift to drive? Is it fixable?
Old Aug 12, 2019 | 05:10 AM
Probably not if he just put in the wrong type automatic trans fluid. NOW, if he put in some fluid that isn't even labeled as automatic trans. fluid then maybe so.
First thing is don't let the guy work on your car anymore. If he couldn't get the fluid right, no telling what else he messed up.
Old Aug 12, 2019 | 05:24 AM
I guess it was when he changed filter and fluid he bought the gallon jug from rural king that said for vehicles made before 2005
Old Aug 12, 2019 | 05:27 AM
So if it was slipping then we changed filter and wrong fluid was put in, now not shifting into drive what do you think I should do?
Old Aug 12, 2019 | 06:09 AM
So, a search on the Rural King website does not show any automatic transmission fluid sold in Gallon jugs.
No telling what was in that jug (unless you tell us what it's labeled as)
Find a good mechanic and/or shop. You're going to need one to repair the damage you've done.
