Transmission problem, car cant drive
Old Dec 10, 2009 | 03:33 PM
permafaust's Avatar
Well, here's an update.
I DO need a whole new transmission, but the Chevy place quoted me $4,250 for a new transmission and whatnot. I almost died when I was told that.
But luckily my dad has a friend who is willing to do it for $2,400. So I most definitely lucked out on that one!
I hope all goes well and I'm not without a car for too much longer!
Old Dec 10, 2009 | 05:08 PM
Old Lar's Avatar
Ow!
Old Dec 10, 2009 | 06:42 PM
permafaust's Avatar
Tell me about it!
Old Dec 18, 2009 | 03:46 PM
permafaust's Avatar
UPDATE:
after nearly 2 weeks without my HHR i am finally going to pick it up right now!
grand total for transmission rebuild : $2,194.43
turns out the guy cut us a better deal than we thought.
i cant wait to drive it again!
Old Dec 18, 2009 | 03:50 PM
ChevyMgr's Avatar
So did you get a transmission assembly replaced or an overhaul?
Old Dec 18, 2009 | 06:35 PM
permafaust's Avatar
overhaul with full 100,000 mile warranty
Old Dec 18, 2009 | 06:50 PM
ChevyMgr's Avatar
So this wasn't done at a dealership then.
Old Dec 18, 2009 | 08:46 PM
oneton's Avatar
I would have tryed "DoverAstro" plan take off pan, Bang out dent, A little JB weld if crack was not to bad. Fill with fluid and try it. if it worked get a new pan and you are set to go. if not then get it fixed. Some stuff in the pan on a car with miles is not always a bad trans.
Old Dec 21, 2009 | 05:08 PM
1970judge's Avatar
Damn J, sounds like a pain in the ass. Let me know if you need anything, you have my number.
Old Dec 21, 2009 | 05:23 PM
IMPALADAKID's Avatar
I know it is a little late now, but it sounds like a new pan, filter and fresh fluid would have fixed your problem. I have seen many times where a transmission blows a line, or leaks out, or holes in pans, and the tranny stops working due to no fluid, but once the cause of the fluid loss is fixed, you are good to go.
I blew a line and lost most of my fluid on a drag strip, fixed, filled drove home.
I know you have some slip, followed by heat, which would kill the transmission, but if you loose it as fast as a hole in the pan would allow, it would seem you would stop going before you would overheat the transmission.
sklute
May 17, 2015 02:27 PM
RBodeman
Nov 16, 2012 07:09 PM
working on it
Sep 17, 2011 11:24 PM
Desert Coyote
Mar 22, 2008 08:25 AM
mew7789
Dec 6, 2006 01:08 PM
