Transmission whining...
Old Apr 14, 2016 | 03:54 PM
Which side? It could be an output shaft bearing
Old Apr 14, 2016 | 04:43 PM
1st post states the noise is coming from the transmission area (OP stated he observed this while rotating tire by hand )
If so, time to visit a Transmission repair shop for a diagnosis.
Old Apr 14, 2016 | 06:35 PM
696's Avatar
696
Yeah, not the hub. Already changed 1 and it was a "grinding" sound. This is def coming from the center in the tranny area. Sound coming from the same on both sides. Might have to go to the transmission shop...dang, hate not being able to fix it myself....
Old Apr 14, 2016 | 07:06 PM
Cat Man HHR's Avatar
I'll have to agree. I don't know the internals of this trans, but hearing a "whine" while rotating in one direction and not the other makes me think it might be a hard part inside the unit.
Dropping the pan would be the next step to see if metal is in there.
Old Apr 14, 2016 | 07:47 PM
Ah, the out put shaft bearing is not near the hub, it's in the transmission were the axle shafts go into the transmission.
I agree with FMG , take it to a reputable transmission shop!
Old Apr 15, 2023 | 11:27 AM
miguel812's Avatar
My 2011 HHR 2.4L is doing the EXACT same thing. I tried the brake in gear reving with same result. I'm pretty confident it is not the hub as well. The transmission cooler lines were failing so I changed them and the transmission oil filter, no shavings in the pan and no change in the noise. Really thought it might have been low fluid. Has anyone solved this issue? Thanks!!
Old Apr 15, 2023 | 12:44 PM
greg8453's Avatar
7 year old. Start a new thread.
Old Apr 15, 2023 | 01:04 PM
miguel812's Avatar
why? When I commented it bumped it to the top. And it would alert OP if he’s still active.
Old Apr 15, 2023 | 01:19 PM
You can continue on in this thread. No problem.
Is your passenger side output shaft seal leaking?
Old Apr 15, 2023 | 03:40 PM
The OP hasn’t been back to the site since 2016. Even if he got an alert, he probably wouldn’t respond.
Miguel812
Why does your bio say 2001 HHR ? Typo ?
