Transmission Will not go into reverse after fluid change
Old Sep 8, 2017 | 07:05 PM
sehrule's Avatar
Alright added a quart, checked again. (Car started, level, and warmed up) nothing came out. Added another quart and started. Warmed up. Checked the fluid. This time lots came out so I reckon it had to much. I just left the check open until it was at about a steady drip and closed it. Still can't reverse!
Old Sep 8, 2017 | 07:52 PM
It might be a solenoid problem or a TCM problem, I'd inspect the harness connections at the TCM
Old Sep 11, 2017 | 08:07 PM
sehrule's Avatar
the harness and all connections around the TCM seem to be fine. Is there a way to test the TCM itself? I have a code checker on the way if that will help me. Should be here Wednesday.
aradmahogany
Maintenance and Upkeep
Jul 27, 2015 08:06 PM
Red Pepper HHR
34
Jun 17, 2013 10:39 PM
55f250
Aug 21, 2010 11:10 AM
jbman
Jun 25, 2010 11:47 AM
Black Rose
Oct 16, 2007 10:21 PM
