trouble with codes
trouble with codes
2009-- 2.2 hhr lt
first it ran ok very little trouble with idle i think you called it surging it never would run wright
more downshifting.very little pressure on gas
i did some of the fix to take care of the codes.. some codes are new
ok just the codes and help!!! now it idle fine but when the engine downshifting it dies impossible to drive
PO101 PO102 PO103, and PO113
still trouble
you know besides the codes it keep popping up
( surging, )
i did allot of tests i know it helped but this surging is pulling my hair out
can you tell me did allot of people end up with transmission problems??
give it a little or steady push on the pedal every thing works.
what i have to wait to see what codes come back on
i am not sure what repair shop to go to.
( surging, )
codes-- service
i took the MAF off clean it real good used gloves
i always listen for the click it could have a wire broke
intake and exhauth sensors new plugs also replaced one coil
pressure all numbers are in range 70 to 65 all cylinders
new thermastat and new fluid. ac now works
changed the oil and filter
the gas held 60 lbs of pressure while testing
inline spark all were the same did not see any breaks or miss
over all starts and idles good
i replaced air filter .. someone posted that they or me when i changed it surging started
looking back it wasn't doing any surging when i bought the car
i need a spell check where??
