trouble with codes
Old Dec 23, 2018 | 11:03 AM
So, after the work done, any codes now?
Or would you consider it all good now?
you do say, starts and idles good, but how does it run, shift, acceleration, any issues at highway speeds ?
Old Dec 23, 2018 | 12:43 PM
Originally Posted by roadmap
i replaced air filter .. someone posted that they or me when i changed it surging started
looking back it wasn't doing any surging when i bought the car
The point to that comment was that most people forget to plug the MAF back after a filter change. You had all of the codes and symptoms that produces.
Old Dec 26, 2018 | 01:41 PM
roadmap's Avatar
what is the compression as new i was thinking 180 for each cylnder
my is reading hi at 170 and low at 165
Old Dec 26, 2018 | 03:57 PM
guppy's Avatar
I think I would remove the throttle body and give it a good cleaning. Remove and test the IAT (Intake Air Temp) sensor just above the throttle body and make sure it is plugged in and no broken wires or bent pins. Check the hose from the valve cover to the throttle body, make sure it is attached properly and no tears. I assume you cleaned the maf properly and not spray engine de greaser or something in there?
IAT sensor test
Check the resistance of your IAT and then apply heat to the IAT sensor tip to see if the resistance decreases. If there is no change or an infinite resistance reading, this means your IAT is faulty and should be replaced.
MAF Sensor
Our tech mod and Admin has this wrapped up here
Old Dec 26, 2018 | 03:58 PM
guppy's Avatar
On thread #9, You had told us 70 to 65 psi, now you are saying 165-170. This is why you got the response that you did. Please explain everything in as much detail as possible and proof-read before you post.
Stevie-d
May 16, 2017 06:59 AM
ChevyMgr
Jun 20, 2016 12:02 PM
twistedjay
Nov 3, 2015 12:14 PM
socalHHRguy
May 24, 2012 04:47 PM
scrisp
Apr 27, 2012 10:46 AM
