Twilight Zone
Old Feb 2, 2026 | 08:49 PM
brad594's Avatar
Twilight Zone
All I did was change the spark plugs. Checked connections and all is good. Now…I have a miss and no codes. IDEAS?
Old Feb 3, 2026 | 06:37 AM
Clean the coils where they slide over the spark plugs.
did you install AC Delco 41-103 iridium plugs??
Old Feb 3, 2026 | 11:23 AM
brad594's Avatar
I’m not sure if they were ac delcos
Old Feb 3, 2026 | 11:27 AM
brad594's Avatar
Ngk
Old Feb 3, 2026 | 11:32 AM
There’s your problem! The Ecotec 2.2 was developed around the AC Delco 4-103 iridium spark plug. Sorry you either got told differently at the parts palace counter or succumbed to the these fit and are cheaper pixies!
Old Feb 3, 2026 | 11:41 AM
brad594's Avatar
Ok, boy finicky cars. I’ll change them u today and reply back thank you for setting me straight with the correct information
Old Feb 3, 2026 | 12:34 PM
PulpFriction's Avatar
Still have the old ones? They're normally good for at least 100K. But since you need to replace, might as well be brand new AC Delco 41-103 (iridium).
Old Feb 3, 2026 | 01:08 PM
I’ve seen them on Amazon and at Rock Auto
https://www.rockauto.com/en/partsearch/?partnum=41-103
If you’re old ones are under 100k miles, put those back in, make sure that the little electrode is in place and don’t try to gap them!
Old Feb 3, 2026 | 01:22 PM
What does "I have a miss and no codes" mean? If you don't have a P0300-P0304 you don't have a misfire, unless the crankshaft sensor is not calibrated.
The computer sees a variation in the crankshaft speed as a misfire. Has your crankshaft sensor been replaced with no calibration done?
Yefet
Jan 24, 2023 03:48 PM
jcs_ss_panel
35
Oct 9, 2022 05:40 PM
farmboyhhr
2.2L Performance Tech
20
Jan 10, 2015 01:30 PM
HHR_carnatic
Maintenance and Upkeep
Feb 28, 2012 09:45 AM
hvrod
2.4L Performance Tech
Jan 7, 2006 09:11 PM
