Underhood Fuses Tip
Old May 21, 2006 | 01:08 PM
  #31
Bump!
Old May 21, 2006 | 05:11 PM
  #32
SoCalHHR's Avatar
Originally Posted by yeshua63043
Are there any placed elsewhere that should be checked?
Sure. The Center Stack console has a fusebox on the passenger side. There is a cover held on with 4 body clips - just pull it off to check them and snap it back on when finished.
Also there is a 50A fuse on the batttery terminal (under rear storage compartment), that feeds the front fuseboxes.
Check to make sure it is seated fully so that you don't experience any intermittent electrical problems.
Hope it helps,
Old May 27, 2006 | 01:56 PM
  #33
Applenut's Avatar
2 words
THANK YOU!!!
Old Jun 1, 2006 | 01:43 PM
  #34
cyrus4's Avatar
Lose2
Most of mine were lose, have to check the one under the rear storage compartment. Thanks . . .
Old Jun 4, 2006 | 07:33 PM
  #35
james5011's Avatar
Thanks for the tip!
I bought mine May 30, 2006 and gave her a wash today. Checked under the hood and sure enough just like everybody else said they were loose.
Old Jun 4, 2006 | 08:01 PM
  #36
SindyDix's Avatar
james5011!
Old Jun 4, 2006 | 10:56 PM
  #37
james5011's Avatar
Thank you! Glad to be here!
Old Jul 13, 2006 | 07:08 PM
  #38
Exclamation
Thought it was time to BUMP this one.
For all the new owners....check your underhood fuses. Chances are pretty good all or most are not set well.
When we got Bonnie's, I had the salesman open the hood on a few other HHR's they had, 3 of 4 had loose fuses under the hood!
Old Jul 14, 2006 | 06:39 AM
  #39
Isn't that the reason it has been made a "stickie", so it doesn't get buried?
Old Jul 14, 2006 | 07:08 AM
  #40
courthousedeb's Avatar
I've often wondered the same thing when I see this done in the stickies. The only thing I can think of would be to bring attention to the thread by posting to it, resulting in the red dot. That way, those who may not have overlooked it, will drop in and check it out.
