Update: Outside air temp read problem
Old Mar 8, 2007 | 12:00 AM
ymerej_mortsdnil's Avatar
Talking
Originally Posted by GDZHHR
I have a feeling he's not around anymore. He posted this about a year ago. His last post was 6 months ago.
Old Mar 12, 2007 | 12:24 AM
Over50's Avatar
Originally Posted by viknguy
Hey OVER50 Did the dealer have the BCM's in stock. I'am taking mine in Thursday for the same problem
Don't check the website that often any more ... just got your message notification.
To answer your question, yes, the dealer had the BCM's in stock. But that said, it wasn't long before my temp reading freeze appeared again and remained a problem until winter set in (Michigan) and since then it's worked like a charm, even down to below zero readings. This leads me to believe it's a ambient temperature issue given the location of the sensor up inside the wheel well as well as adjacent to the engine compartment.
Based on having had no problems once the outside temps dropped below 40 degrees (since late November around here) I'll be looking for a reappearance of the temp freeze problem as the weather turns warmer over the next couple of months.
Old Mar 12, 2007 | 09:11 AM
viknguy's Avatar
Took mine in and they replaced the BCM then reprogramed the computer. So far it seems to have corrected the problem
Old Mar 13, 2007 | 10:55 PM
Over50's Avatar
Angry
Well......it's got to be an ambient temp thing with the sensor. The temps reached an abnormally high 73 degrees today (normal is 40 for this time of year in Michigan) and my outside temp reading was a constant 47 degrees for most of the time I was out and about, then suddenly corrected to 71 on my way home...
Again, my temp readings have been normal since below 40 degree temps set in around the latter part of November.
I have a list of problems that I'll have addressed in a week or so when I take the car in for a 9000 mile oil change that include the temp issue plus a loud squeak when I shove the shifter into Park and an anemic/sick sounding horn - as if the horn button contact is making and breaking when I push on it...
Oh, and my gas mileage has dropped to around 18-20 mph for city driving, down from 23 to 24 I was getting in the first 6 months I had the car...
Tell me again why I bought this thing...
Old Mar 13, 2007 | 11:58 PM
Talking
you mean other than the fact that it is the coolest car EVER?!?
Old Mar 16, 2007 | 11:50 PM
Over50's Avatar
Thumbs down
You're wrong on that one. The coolest car ever was the 1965 poppy red, 4 on the floor Ford Mustang convertible with white interior I had.
Old May 30, 2008 | 02:04 PM
HHR4JK's Avatar
my outside air temp indicator has stuck several times... one time for over 5 hrs. then suddenly jump 20 degrees to what it was supposed to be..
took it to the dealership... they stated they put another sensor on it but since they can't duplicate the situation and they cant find a code.. thats the way it is...
on the way to memphis last week stuck again... well i am on the road cant take it into the dealership..but i called them to let them know....
oil change told them about the sensor sticking again...still cant find any code or duplicat it....
cant seem to get it to a dealership before it starts working again.....
oh yea i know go certain speed for certain time...... but i was driving 85 for over 2 hours... and still stuck 28 degrees lower than the real temp. was.
maybe i was going to fast for it to keep up with me..... yea right....
any suggestions.....
lw9090
Oct 5, 2015 01:21 PM
Silverfox
Maintenance and Upkeep
Sep 28, 2013 09:34 PM
Wifes07LT
Sep 3, 2013 08:44 PM
beachbum1970
Jun 24, 2010 05:46 AM
jshandra
Oct 28, 2006 03:32 PM
