Valve cover gasket replacement
Old Oct 21, 2023 | 04:08 PM
guppy's Avatar
VALVE COVER GASKET REPLACEMENT
Broke all three plastic clips in the valve cover
How do you remove the broken parts?
Do you replace the plastic clips or is there a better alternative?
Valve cover bolt grommets. Do these need to get pressed back into the valve cover or is torque the bolt suffice?
Old Oct 21, 2023 | 04:17 PM
What plastic clips? Do you mean the ones that hold the wires and tubes? A picture might help.
Just press all of the rubber bits into the slots then torque.
Old Oct 21, 2023 | 05:22 PM
There are replacement tie wraps available for those plastic clips.
I push the grommets into their place then install the valve cover and torque to 89 inch lbs
slonny
Nov 26, 2022 06:28 AM
ScareDe2
Maintenance and Upkeep
May 12, 2021 07:36 AM
GDZHHR
"How To" Tutorial Library
20
Jun 9, 2014 11:47 PM
KissMy08SS
Mods - Engine/Exhaust
14
Feb 15, 2012 03:19 PM
Lee3333
Sep 13, 2006 09:02 PM
