Valves Hit Pistons
Old Jan 7, 2021 | 12:38 PM
  #61
I suggest you get a set of 12625029 the AC Delco brand and check with RockAuto about returning those other injectors. They could be the problem, then again so could the MAF sensor if it’s aftermarket or the connector pins are damaged, it’s very plausible!
Old Jan 9, 2021 | 10:05 AM
  #62
tr34's Avatar
Yep, got the AC Delco injectors and that fixed the issue. I guess I learned my lesson to not use anything other than AC Delco for injectors. Thanks for all the help and advice, appreciate it a lot!
Old Jan 9, 2021 | 12:47 PM
  #63
Injectors, thermostat, spark plugs, SS LCA’s, MAF sensor...... the list goes on!
Your welcome
Hot Bite
Aug 20, 2018 06:58 PM
fastsuv
Mar 24, 2018 02:46 PM
hhrrat
2.2L Performance Tech
Nov 19, 2014 01:14 PM
vulcan scott
Nov 11, 2014 06:17 PM
M.Harper
24
Jul 30, 2014 08:20 PM
