Variable Valve Timing Solenoid Stuck
Old Oct 27, 2014 | 06:18 AM
In fact, let's merge the 2 threads!
I thought those were the wrong codes, I just wasn't interested enough to look it up.
Old Oct 27, 2014 | 01:42 PM
I Googled the P0016 and P0017 codes and found them in relation to the crankshaft position sensor and Whopper's guide to repairing this issue
http://www.chevyhhr.net/forums/probl...-needed-38696/
Old Oct 27, 2014 | 04:56 PM
P0016 Crankshaft Camshaft Position Correlation DTC This link may help.
Old Oct 27, 2014 | 06:15 PM
Yeah My page won't open, sorry about that
Old Oct 27, 2014 | 06:48 PM
jay loukakis's Avatar
Originally Posted by mstinso
Well got them in, it took two of us, one to push down and the other to wiggle it with pliers. Unfortunately they didn't fix the problem. I've got two codes. P0016 and a P0017. Didn't have time to mess with diagnosing and got both solenoids cheap on amazon for about $25 a piece. In fact It's been over a month before I could get the time to even get these swapped out as I been so busy lately and in poor health. I had a other vehicle to drive but had my brother just take it as I thought the problem was fixed until I just started it again after a number of restarts without the problem coming up.
I think usually theirs more codes that pop up with the ones I have, but I figured I'd take a chance. Their was some crude around the old ones too which shocked me. I don't know if something's pugging the oil galleries or I am looking at a timing belt issue or even cam replacement at this point. But those are the only codes I am getting. Anyone know from experience with just those two codes alone what's been the common culprit with their own experiences.
Whopper had the solution as I had 2 mechs. did not know what to do, boufhr from the local dealer $115.00 for both and only took about 20 minutes total solved the problem thanks to Whopper. YIPPEE
P0757
Drivetrain (Excluding Engine)
Jan 23, 2015 07:39 AM
Diskokid
Nov 11, 2012 01:33 PM
jonboyb
2.0L Performance Tech
Apr 29, 2009 06:23 PM
sp52075
2.4L Performance Tech
15
Jan 6, 2009 02:34 PM
07LTGuy
Aug 6, 2008 03:39 PM
