vibration when between 60 and 70 mph
Got new tires Goodyear Assurance Ultra tour tires (215/55/16) on yesterday(2010, LT, 2.2L). The set before this only lasted about 23,000 miles (champiro 128) and purchased this past august. Have a slight vibration between 60 and 70, so had them check it out this morning. They now say I have a bent rim that is causing this. Never felt vibration on set before these. So, is it possible to have bent rim and feel no vibration or is bent possibly caused when taking tire off rim. They showed me it spinning when balancing the tire and you could see it that it wasn't smooth at spot they said.
You have to be trying to bend a rim with todays tire mounting machines.
There is a tiny chance if the rim is bent in. If its bent out, you did it.
If your previous set lasted only 23K I am betting you have need of some suspension work, which could also cause a vibration.
The point being it's bent , out of round, needs to be replaced.
So check out the classified ads for anybody selling rims!
They should be like this
http://m.ebay.com/itm/261758102315?fits=Model%3AHHR
Zagohhr
Oct 22, 2010 07:54 AM
