VUE V6 P0010
Old Jul 18, 2016 | 07:45 AM
brst's Avatar
VUE V6 P0010
I'm replacing my actuators soon after reading this thread. Looking at a relative's 2009 Saturn Vue and it's giving the same P0010 code...
Know anything about them?
It is the V6 - 3.5 - it "stumbles" when increasing load (accelerating or uphill) at RPM's lower than 1800.
I was going to start looking at plugs, wires and coil packs...
Old Jul 18, 2016 | 08:27 AM
These Code numbers are "generic" they mean the same thing from car to car.
Old Jul 18, 2016 | 09:09 AM
brst's Avatar
Awesome! Are they difficult to find on the engine (for replacement?)
I'm guessing there are two of each on a V-6?
Having trouble getting the plastic engine cover off to 'inspect'. The oil filler neck is where it seems to be sticking... Any hints/suggestions?
Old Jul 18, 2016 | 09:25 AM
The HHR doesn't have a V6, so I can't offer direction
Old Jul 18, 2016 | 09:28 AM
brst's Avatar
Same code reading on 2009 Saturn Vue??
Sorry OldBlue, I had changed the subject to a 2009 Saturn Vue because it has the same code as my HHR... The Vue has a V6
Old Jul 18, 2016 | 10:21 AM
Different car, engine, platform, electronics etc. The code numbers are just standard numbers used for any car that has a OBD II.
If that Vue had a 2.4 Ecotec, then the code and it's fix may be similar to the HHR. Since it's a V6, I would say check out the Vue forums.
Old Jul 18, 2016 | 10:24 AM
Ah, then perhaps this will help!
Saturn Workshop Manuals > VUE FWD V6-3.6L Hybrid (2009) > Engine, Cooling and Exhaust > Engine > Actuators and Solenoids - Engine > Variable Valve Timing Solenoid > Component Information > Service and Repair > Camshaft Position Actuator Solenoid Valv
Old Jul 18, 2016 | 10:55 AM
Moved as to its own thread under Problems section, rather than hijack the How-to thread with non-HHR questions.
Old Jul 18, 2016 | 01:01 PM
Sorry, I thought that my curt answer would shut it down.
Old Jul 18, 2016 | 01:20 PM
No problem donbrew. He sounded a bit desperate so I moved the posts rather than just delete them. VUEs are about as common as Ferraris in most places, like this forum.
