VVT solenoid leak 2011 2.2L
Old Mar 22, 2025 | 04:16 PM
Atomicthunk's Avatar
I have oil leaking from the VVT solenoid because the 10mm bolt is stripped. It leaks a lot when the engine is running. The seal seem to be be good, it is just a problem with the bolt being stripped. I was thinking of getting a larger size self tapping bolt and try that, or J B Weld the VVT in. Can the part of the engine where the two VVT solenoids bolt into be replaced. Need to get this fix on my son's HHR so I can get my truck back from him. Any Ideas? Thanks in advanced for any suggestions.
Old Mar 22, 2025 | 04:57 PM
Try retreading the cylinder head and put in a new bolt.
Old Mar 24, 2025 | 01:53 PM
Bonez's Avatar
You can rethread with a slightly larger bolt or you can buy a Heli-coil kit and still use the proper bolt.
Old Mar 24, 2025 | 09:28 PM
guppy's Avatar
A thread repair kit would likely be best. There are several different manufacturer's; helicoil, timesert, E-Z Lok, Bigserts, Keensert, etc. Just make absolutely certain that you do not get aluminum shavings inside the solenoid cavity. watch some youtubes on repairnig threads or take the entire car to a machineshop and let them do it. You might want to use a torque wrench when working on a car..
Old Mar 26, 2025 | 09:40 AM
PulpFriction's Avatar
Heli-coils preserve more material.
A JBweld job should be fine because little force is needed to retain the solenoid.
Beejmamdude
Jun 10, 2024 10:44 PM
advisual
Sep 20, 2022 12:09 PM
FirstGenHHR06
19
Sep 2, 2022 01:09 PM
New to me HHR
Sep 2, 2021 06:39 AM
