Warning bell going crazy!
Old Jul 25, 2019 | 08:35 PM
Ralphie68's Avatar
Sometimes, when I open the driver's door to my 2011 HHR, the warning bell goes nuts, as if I had left the key in the ignition. The key is out. When I push the delayed locking switch, like I always do, all the doors immediately lock, but the drivers door, which is open, then unlocks. The bell keeps ringing. When I exit the car and close the door, I have to lock the door with my key. Sometimes when I come back to the car, the bell doesn't ding when I open the door. Sometimes it does. This seems to be completely arbitrary.
This has been happening for several months now. I bought the car with 100,000 miles on the clock, and it now has around 140,000.
Any ideas?
Anybody?
Bueller?
Anybody?
Old Jul 25, 2019 | 08:58 PM
Why not lock it and unlock it with the FOB?
Old Jul 25, 2019 | 09:21 PM
Has the ignition recall work been done ?
Old Jul 25, 2019 | 09:51 PM
I guess if nobody answers in 23 minutes panic sets in.
Old Jul 25, 2019 | 10:13 PM
And you're not leaving the headlights on?
Old Jul 26, 2019 | 08:04 AM
It could be low battery voltage, have the battery load tested and the charging system tested.
Old Jul 26, 2019 | 12:47 PM
Ralphie68's Avatar
Greybeard: Lock button on the fob doesn't work, and yes, I changed the fob battery. It's just worn out.
firemangeorge: Checked the GM recall site, punched in the VIN, and it said there are no outstanding recalls.
RJ_RS_SS_350: Headlights are off.
Oldblue: Battery was changed one year ago. I'm afraid that wherever I take it for a charging system check will prescribe a new battery whether or not I need one. I have trust issues whenever anyone else works on my car.
Thanks anyway guys. Anybody else?
Old Jul 26, 2019 | 01:06 PM
If you have a Digital meter, take a voltage reading key turned off , what’s the voltage, above 12.4 volts or higher.
Then start the HHR and take another reading, should be above 14 volts.
The alarm system went nuts when my OEM battery died , 12.3 volts and a 2 dead cells.
Old Jul 26, 2019 | 05:01 PM
Pretty cheap and easy to get a new fob keypad.
Old Mar 2, 2020 | 12:00 AM
Toyasock's Avatar
my same issue I'm having did u ever find out what was your problem with your hhr I have a 06 lt
