water in the floor board passenger side
Old Aug 2, 2014 | 02:15 PM
coyote67's Avatar
I have water in the floor board, passenger side, every time it rains. Why?
Old Aug 2, 2014 | 02:30 PM
Because you have water leaking in. If your question really is how can I find information about water on the passenger side floor then:
If you have a 2006 the search term would be "butyl patch". If not that and you have a sunroof the search term would be "sunroof drain".
Old Aug 2, 2014 | 03:11 PM
Hi coyote67,
I'm very sorry to hear this! We will be happy to look further into your concern to try and find the best resolution. Feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name. We look forward to helping!
Kristen A.
Chevrolet Customer Care
Old Aug 3, 2014 | 06:24 PM
Ron S's Avatar
Welcome to the site. Don has the right info to search.
Old Aug 10, 2014 | 07:53 PM
Alvis's Avatar
coyote67,
I had the “butyl patch” problem last year and fixed it with a homemade piece of aluminum (ref. my several posts). It seemed that the problem returned this year, but I was pleased to learn that this year’s problem was merely a clogged AC drain. Diagnosis of it for me was very confusing because the pass-side floor got wet after rain. For a while, I was convinced that I had a windshield leak. But then I checked this forum and learned how to fix the clogged AC drain. The symptoms occurred after rain because I had the AC running in hot, humid weather.
Here are my words of wisdom:
The glove box comes out easily with the removal of just one screw.
If the pass-side floor is wet and the cabin air filter is dry, then the problem is NOT due to the “butyl patch” on the cowl.
Old Aug 10, 2014 | 08:11 PM
to the forum!
Here's a link to the famous, or infamous, "How To" thread on the dreaded Butyl Patch water leak....
https://www.chevyhhr.net/forums/how-...t-night-14263/
Old Aug 11, 2014 | 04:43 AM
geg's Avatar
geg
Originally Posted by 843de
to the forum!
x2
Another may be to blame for the door seal.
At the time, GM even withdrew their cars for a free replacement of the seal.
Water leaks in the seal, Water accumulates on the rubber hose - "accordion" (wiring inside the hose) and flows into the cabin. This was one guy from Belarus.
Sometimes, it is better to use silicone grease. Just check "accordion" after rain, it wet or not.
Countrygrl55
Aug 8, 2019 02:36 PM
pindars
Drivetrain (Excluding Engine)
Aug 5, 2014 06:28 AM
HHR454guy
Oct 14, 2013 06:13 PM
CruzHHR
Sep 29, 2013 09:27 AM
wildman1122
Jan 28, 2010 05:33 AM
