Weird battery issue
Old May 30, 2010 | 04:22 AM
Czechman's Avatar
Weird battery issue
I don't drive my '09 HHR very much, usually about 30 minutes a week. Having said that I've had my battery go dead twice. The first time it happened I recharged it - no problem.
It's happened again. When I try to start the car I get the typical dead battery symptoms, standard stuff. However, this time when I tried to recharge the battery (I know how, done it before) two different chargers read a fully charged battery.
What does it mean when the battery acts dead but reads fully charged?
How long should you be able to park your HHR without driving it before the battery goes dead?
Are batteries covered under the warranty?
Any help is greatly appreciated.
Old May 30, 2010 | 08:19 AM
2 years in my warranty, dealer covered my battery when it wouldn't hold a charge.
Old May 30, 2010 | 09:17 AM
steven&cat's Avatar
Dealer replaced my battery in Jan. it was around 2 years old.
Old May 30, 2010 | 10:47 AM
Czechman's Avatar
Am I safe to assume that I can have it jump started and drive it to the dealer with a dead battery?
Old May 30, 2010 | 12:11 PM
RFT's Avatar
RFT
Shouldn't be a problem. As long as the alternator is good, it will provide enough power to run everything until you turn it off again.
Old May 30, 2010 | 03:22 PM
Laco's Avatar
It’s not uncommon to have a battery show full charge, yet not have enough real charge to start a car. Your battery has what we used to call a surface charge, but won't hold a 'deep' charge. I have had a number of batteries fail that way, though usually they are five to seven years old when it happens. Yes you can safely jump start it, and drive it, but it probably won't restart if it sits for any period of time. If I recall correctly twenty to twenty five days is the maximum the HHR can sit without parasitic battery drains killing the battery.
Old May 30, 2010 | 03:35 PM
Czechman's Avatar
Thanks Laco,
Let's say the car sits for two weeks and is then driven at highway speed for a half hour. Is that sufficient time to completely charge the battery?
Old May 30, 2010 | 03:48 PM
BlackknighT's Avatar
Most likely not. If you keep the HHR in your garage buy an electronic trickle charger will only supply enough energy to your battery as it senses it loosing juice. Even when you buy a new battery it does not come fully charged unless it is kept on trickle charges in the store/shop.
Mike
Old May 30, 2010 | 05:09 PM
tucsondivots's Avatar
Has anyone replaced their battery? Is there a replacement available with the vent and the right size except the Delco? I cannot find one shown at AutoZone, Checker, Costco, etc.
Old May 30, 2010 | 07:05 PM
Czechman's Avatar
Originally Posted by BlackknighT
If you keep the HHR in your garage buy an electronic trickle charger will only supply enough energy to your battery as it senses it loosing juice. Even when you buy a new battery it does not come fully charged unless it is kept on trickle charges in the store/shop.Mike
I have one of those "smart" Battery Tenders and used it for a while but then stopped because I was driving it about 40 miles one day a week and figured that would be sufficient. It sounds like the battery is defective but I'll find out tomorrow.
It will be on the Tender from now on.
