Weird sound when starting engine
Old Feb 22, 2016 | 11:11 PM
NappiiRoots's Avatar
So I have been experiencing a strang sound when starting my car for a while now. I found this YouTube video online where someone else is experiencing the same issue except not as bad as me. The sound will last about 25 seconds usually. Can someone please finally identify what the heck is causing this and if possible can someone give me an idea about what I might expect to pay to get it repaired?
Old Feb 22, 2016 | 11:27 PM
Did you not read the comments at the bottom of the youtube video?
The originator of the video explains what exactly the problem was, and what was done to fix it. Mind you he did refer to a timing BELT.
Old Feb 23, 2016 | 07:20 AM
Figure $800-1000 for a timing chain, mostly labor.
Old Feb 23, 2016 | 09:44 AM
Yes, I did read the comments but I needed a more informed opinion and thus I asked here.
Oh wow, that's a lot more expensive than I hoped. It may take me a little while to come up with that kind of money. How long do you think I can keep driving with this issue?
Old Feb 23, 2016 | 09:49 AM
You mean like this back in 2013?
https://www.chevyhhr.net/forums/how-...-rattle-46159/
I believe you will be changing the timing chain, not a hard impossible job
Timing Chain Service Procedures GM 2.2L L61 Ecotec, Camshaft Sprocket
Old Feb 23, 2016 | 10:51 AM
Stealth HHR's Avatar
Here is a tricky one for you guys. I have already replaced all the items mentioned (timing chain, tensioners, chain behind the timing chain and tensioners. Best part is I get the same starting noise, but not every time I start it. Seems to happen when the car sits or is on an incline. Oil not staying in the right places all the time is my guess, but could be normal for this engine. Any help with the answer would be interesting to me also.
Old Feb 23, 2016 | 11:05 AM
prod's Avatar
The SS is noisier in general. even the higher pressure fuel injectors make a noticeable ticking. Did you also replace the nylon chain guides and double check the valve timing? After that you could be looking at valve train wear or bearings elsewhere, but that is not a common issue.
Old Feb 23, 2016 | 11:13 AM
On mine i replaced everything I could. On thing is the the manual didn't describe the VVT cam sprockets and I still have the originals. I debated changing them since there is some wear on the plastic in one spot that looked like rubbing. I figure it was wear on the inside of the sprocket that can't be serviced. Could that cause additional noise from the valve if the VVT has some internal wear not allowing the valve to close at the right time?
Old Feb 23, 2016 | 01:05 PM
Could be the VVT , could be the oil as you mention, the DI injectors wouldn't be noisey on start up
Stryker
Dec 8, 2018 02:58 PM
skyline26
Oct 29, 2014 04:26 PM
laimikath
14
Mar 22, 2013 03:51 PM
LolaIsMyHHR
Nov 30, 2011 08:05 AM
dschoeck
May 11, 2009 06:11 PM
