wet floor board
Old Jun 30, 2024 | 01:47 PM
littleshell's Avatar
wet floor board
floor board on passenger side of 2010 HHR gets wet when it rains
Old Jun 30, 2024 | 01:55 PM
Close the window when it rains.
Or, look at the door seal. Do the dollar bill test; close the door on a dollar bill, it should be hard to pull out.
Does this happen when the defrost or AC is running? Check the evaporator drain; is there a puddle under the car if you sit still with the AC on?
Old Jun 30, 2024 | 02:21 PM
Check the rubber boot between the door and the body
This should be tight to the body and door.
Old Jun 30, 2024 | 02:25 PM
Is there a sunroof? There is a drainage tube to each corner or the cabin. Check behind the kick panel.
Rixbae
Mods - Interior
Nov 29, 2019 09:04 PM
DIESAHL
Oct 1, 2016 09:55 PM
HillsdaleHHR
Mar 18, 2010 10:15 PM
REDHHRSS
Oct 11, 2008 08:34 PM
Black Rose
15
Oct 5, 2007 08:33 AM
