Wheel bearing or Strut bearing
Old 07-08-2019, 07:42 AM
vogtrj's Avatar
Symptoms: The brake has a 'rub' right on the top, outside edge of the rotor which is shaving the corner off of the rotor. I've noticed an occasional popping from the right front when I make a tight corner turning around in the cul-de-sac.
History: I changed the brakes a couple weeks ago. When I pulled the caliper off, a helicoil fell out of the hole. The thing had been stripped out. There had been a slight issue with rubbing along the top, outside edge of the brake rotor that I (probably wrongly) attributed to the caliper probably being misaligned due to the stripped out hole. I replaced the caliper.
Hub?: Last weekend, I noticed the rub was back. I looked and saw that the corner was being taken off of the rotor. I jacked the car up and yanked on the tire to test to see if the bearing was bad. It was nice and tight. At this point I was stumped.
Strut bearing?: Over this past weekend, I started doing more research. I discovered on other threads here that there is a strut bearing that can go bad. Being a novice, I had never heard of a strut bearing.
Could a bad strut bearing cause my symptoms? What is the most likely issue?
If it is the strut bearing, would I purchase a strut mount kit or just a new bearing?
(Thanks all for your patience, once again, with a novice mechanic :))
vogtrj is offline
Old 07-08-2019, 07:52 AM
The strut bearing is at the top of the strut, attached to the body by the three studs and nuts.
https://www.1aauto.com/chevy-cobalt-...r/i/1asfk01368
your issue seems to be a stripped out calliper mounting thread .
you should replace the steering knuckle itself and the rotors
https://www.gmpartsgiant.com/oem-che...g_knuckle.html
Oldblue is online now
Old 07-08-2019, 07:57 AM
vogtrj's Avatar
I replaced the caliper which is what had the stripped threads. Do you still think I need to replace the steering knuckle?
vogtrj is offline
Old 07-08-2019, 08:24 AM
I don't understand, could you please post a picture? it's easy, link in my sig.
donbrew is offline
Old 07-08-2019, 08:42 AM
You mean which bolt hole had the helicoil
Old 07-08-2019, 08:45 AM
vogtrj's Avatar
A bolt hole in the caliper itself had the helicoil. It received the bolt that ran through through the steering knuckle.
vogtrj is offline
Old 07-08-2019, 08:47 AM
The threaded hole in the calliper brackets, much easier to replace
https://www.autozone.com/brakes-and-.../chevrolet/hhr
Old 07-08-2019, 08:51 AM
vogtrj's Avatar
Unusual wear along with a noisy rub on Rotor - 45 degree angle wearing away from outside edge.
Corner wear like this:
vogtrj is offline
Old 07-08-2019, 09:05 AM
vogtrj's Avatar
That is fixed. I replaced the caliper.
vogtrj is offline
Old 07-08-2019, 10:06 AM
I've never seen anything like that. Something metallic is rubbing it, not pads. Maybe wrong size rotor?
The strut has nothing to do with the caliper to rotor geometry. Hubs cause a lopsided wear pattern on the pads and tires. The inside of the tread gets bumpy from bad bearings
donbrew is offline
Quick Reply: Wheel bearing or Strut bearing
