Wipers are acting goofy
Old Jul 31, 2018 | 11:25 AM
JazzDad's Avatar
I turned the wiper switch to the low setting. After a while they stopped in mid-sweep across the windshield. Turning the switch to the high speed got them moving again. Moved the switch back to low and they worked fine for a while, then stopped again part way through a sweep. Turned the wiper switch to off and they kept running.
There is no discernible pattern to the problem. Wiggling the switch does not change what is happening with the wipers. The only way to get them moving when they are stopped is to step through the switch positions multiple times. Conversely, the only way to stop them when they are running is to step through the switch positions multiple times.
I had a similar problem with an F-150 and solved it by changing out the wiper switch/ stalk.
1. Do y'all think it is the wiper switch in my HHR causing this similar problem?
2. Is this switch easy too replace?
Ref: Part Number: ACDelco #D6249D
Old Jul 31, 2018 | 12:11 PM
solman98's Avatar
It does sound like the wiper stalk.
Old Jul 31, 2018 | 12:15 PM
Cat Man HHR's Avatar
Here's a video for a 2008 Equinox , bet it's very close how to change yours.
Old Jul 31, 2018 | 01:16 PM
Here is one for the HHR; it is a bit different getting to the switch, after that it is pretty much the same. This guy is crazy, I guess he didn't know the steering column is adjustable.
Old Jul 31, 2018 | 02:29 PM
Seems like the switch has worn out, RockAuto offers us a discount
https://www.chevyhhr.net/forums/supp...-2018-a-60583/
https://www.rockauto.com/en/catalog/...er+switch,4856
its an easy switch to switch.
Old Aug 1, 2018 | 10:41 AM
JazzDad's Avatar
Re: "This guy is crazy, I guess he didn't know the steering column is adjustable." Maybe I will remove the instrument cluster bezel, too. After all, what's the fun if you can't take a simple job and make it difficult?
Re: "its an easy switch to switch." How much wood, does a woodchuck chuck...
The part has been ordered and I will post back on the ease of installation and the end result.
Old Aug 6, 2018 | 10:56 AM
JazzDad's Avatar
That did not fix it.
Please, don't let it be the BCM...
Can a BCM be re-flashed at the dealer?
Old Aug 6, 2018 | 11:05 AM
It could be the wiper motor itself, highly unlikely the BCM
Last edited by Oldblue; Aug 6, 2018 at 11:21 AM. Reason: Auto correct problem or big fat fingers!
Old Aug 6, 2018 | 11:13 AM
Fwiw. The wipers on my old Dodge truck had the same symptoms you described in post #1. It took a new wiper motor to fix mine after "trying" a new switch.
Old Aug 6, 2018 | 11:19 AM
fastsuv's Avatar
Could be a dead spot on the motor (there are multiple windings in the motor usually) and if it happens to go slowly through the dead spot it stops. Maybe that's why there is no pattern.
A bad BCM is less likely than the motor. I would expect the wipers to be dead completely if the BCM was bad (burned out output driver for the wiper motor).
Steve
