Won't start after rinsing eng compartment.
Old Jun 22, 2014 | 03:30 PM
LOl - true dat!!! But ya see, I am always right!!! Well, not really - once I thought I was wrong, but it turns out I was only mistaken.
Old Jun 22, 2014 | 04:24 PM
Lawagz's Avatar
As I used to tell my late wife, jokingly, I may not always be right, but I'm never wrong!
Old Jun 22, 2014 | 05:06 PM
At least I was not the only one confused.
What exactly do you mean by "turning over" "cranking" "running" and "starting"? Evidently you have different definitions.
Old Jun 23, 2014 | 09:03 AM
db/sb's Avatar
Let me see if I've got that....you were wrong about being wrong.....I like it!
Old Jun 25, 2014 | 01:25 AM
Hubbcapp's Avatar
Thumbs up
Hey good evening guys, Whooper you hit it on the head, thank you kindly Sir. To all others my apologies for the lack of clarification, " donbrew " and "Whopper" you guys are awesome, after following your advice it finally started and stayed running yesterday but as luck would have it the eng light popped on & thru a (P0107) code popped up. Oh well... It's running at least. Thanks again guys and of course any advice is welcomed.
Old Jun 25, 2014 | 02:27 AM
Good stuff.
Ok - P0107 = Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage, which points to the MAP sensor. It's located at the front of the engine, just above the throttle body - and is in a rather snug spot (and probably a good spot to collect water/moisture).
Here is a link to a thread about replacing/inspecting it: https://www.chevyhhr.net/forums/how-...acement-49757/
The writer said it was $116 at his dealer, but I think I paid about $60 or so at Autozone. I picked up the part, but haven't replaced it yet as the code was a one-time hit for me.
Try unplugging it, and hit the insides of the plugs with WD40 (I swear by that stuff - can't you tell?). Or, give it another day or two and see if it too dries out.
do keep us posted - this was an interesting one (I am easily amused :)....)
Old Jun 26, 2014 | 02:15 PM
for the solution to the P0107 code - see https://www.chevyhhr.net/forums/prob...olution-50958/
capp002
Mods - Engine/Exhaust
20
Oct 8, 2011 06:24 PM
cjnappo
36
Sep 14, 2006 09:04 AM
