Wrong Sway Bar Links
Old Mar 7, 2010 | 09:28 AM
user 830273's Avatar
Hi guys, maybe someone can steer me to the correct parts.
I searched here and determined my front end clunk might be the sway bar links, so I pulled one off and sure enough, it was loose at one end. So I looked at napaonline.com and found a Sway Bar Repair Kit part# NCP 2651633 listed for the HHR. I went to the local store and picked up two of them and didn't really pay attention because they looked like the right part. However, when I got home and went to put it on, it is longer Anyway the store was closed by this time and I can't return them until tomorrow, but maybe someone here knows the right part number for the links at NAPA or another parts place? These are made by Dana Corp. and they look to be a better design than factory. I read here about Moog replacements, what parts house carries those?
Old Mar 7, 2010 | 10:42 AM
an08HHR's Avatar
fatdog When I did the search. Looked up at advance auto parts for their PN (moog K750012) then put that # into the interchange block on Napa's site and they came up with #2651833 Your # was 633 not 833- typo or that would explain the wrong part. I found Napa does have both p/n's so which is right? I'm guessing the 833 number maybe correct.
hopes this helps.
Old Mar 7, 2010 | 11:05 AM
Hey thanks, that one looks like it is probably the correct one, it is shorter 281mm compared to 333mm for the 633 part#. I'll compare at the store Monday if they have it in stock. No Advance auto parts stores around here.
Zaydoc
11
Apr 8, 2021 11:46 AM
Meltingside
Aug 3, 2015 07:12 AM
redridehhr
Oct 22, 2013 01:01 PM
spotty
Aug 15, 2012 11:37 AM
