need help--removing door panels
Old Oct 1, 2006 | 01:37 PM
what am I going to run into? do I just pull it off or are there things I need to disconnect?
any info related to this is helpful. Thanks
Old Oct 1, 2006 | 01:54 PM
Thanks Mike....
I need to know this also.
Old Oct 1, 2006 | 02:32 PM
cvrogershhr's Avatar
There was a thread to this, but it seems to be blocked by the administrator of the site. (here)
Old Oct 1, 2006 | 04:32 PM
teech's Avatar
check out Captain Howdy's speaker swap in the How-To section
Old Oct 1, 2006 | 04:41 PM
I looked, its not the anymore. At least I couldn't find it.
Got them off. Two bolts in each door pocket and then one behind the handle. Then it comes off real easy.
Old Oct 2, 2006 | 04:24 PM
the_shmoo's Avatar
These are instuctions from repair manual. for door panel removal, hope they help.
1- Door armrest,pull cup liner.
2- Remove 2 cup screws.
3- Door inside handle cover.
4- Remove door handle screw.
5- Remove door panel, there are 9 panel clips.
Hope this helps, if you have'nt already figuered it out. Can send a diagram if needed.
Old Oct 2, 2006 | 04:25 PM
the_shmoo's Avatar
sorry I see you already have it, gave me a chance to post a reply.
Dutchman09
0
Aug 4, 2010 06:23 PM
jmarines
Apr 1, 2009 05:15 AM
1HotHHR
May 16, 2008 05:34 PM
