A/C just stopped working
Old 09-13-2016, 07:26 PM
VinceP's Avatar
O.K. its been a week now and the a/c is working like a champ. I did nothing to it except check the pressure. Just started working all by itself. I suspect it was the expansion valve. Time will tell I guess.
Thanks for the suggestions guys.
VinceP is offline
Old 07-24-2017, 02:44 PM
Tou Parish's Avatar
AC Hot and Cold
I have a similar A/C issue, too.
Start car, turn AC on. No cold air. Drove around for about 15 mins and at a red light, for grins and giggles, I turned the car off and then immediately back on. Suddenly the AC works fine, blowing out ice cubes thanks to the new Freon charge AND new relay switch.
This happens about every 3 or 4 times I turn the car on. Doubtful if it is a Freon or relay issue since both were upgraded 2 weeks ago. When the AC isn't working, the AC light turns on/off when I press it but no idle change, no familiar "click" of the AC coming on. Thinking this could be a resistor issue?
Any idea what this could be?
Tou Parish is offline
Old 07-24-2017, 03:25 PM
Is the check engine light on?
What is the coolant temp? Not the analog gauge.
My guess is that you need a new t-stat. 180F, the expensive one from GM.
Old 07-24-2017, 03:34 PM
Welcome to the site, I see you have a 2006, so yes time for a new AC Delco thermostat and new Dexcool, not the green stuff, Dexcool
Here's a how to
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Old 07-24-2017, 04:22 PM
Maybe an answer to the above (in blue) is needed. If you've had to add freon or recharge the system, then some type of repairs must have been done. Freon doesn't go bad and need to be replaced.
Without knowing what's been repaired, I'll not guess at the problem just yet.
Old 07-02-2018, 11:30 PM
gusta1960's Avatar
Compressor type ?
hi, I am new in this forum. My wife’s car is 2007 hhr 2.2L LS. And I need to replace de Ac compressor , but I’d learn there two types and I need to know how identify my car s specific to buy the right one. Any help would be appreciated . Thanks
gusta1960 is offline
Old 07-03-2018, 06:10 AM
RockAuto has component kits available for your HHR
https://www.rockauto.com/en/catalog/...nent+kit,17507
Old 07-03-2018, 08:41 AM
If you told us exactly what you need to know we might be able to help.
Old 07-03-2018, 05:20 PM
gusta1960's Avatar
OK, how I know if my wife's 2007 hhr ls have a cvc air compressor or Sanden pxv16?
Thanks
Old 07-03-2018, 05:29 PM
This is the only help I could find, evidently it is in the shape of that front plate on the clutch.
Quick Reply: A/C just stopped working
