How to replace Tweeters in my 08 SS?
Old Jan 10, 2008 | 08:27 PM
HHRAZ's Avatar
Has anyone replaced the tweeters in the A pilar of the HHR?
I am looking at a set of speakers from Polk and wondered how hard it is to put the Polk Tweeters in the Factory Location?
Old Jan 10, 2008 | 08:46 PM
stick's Avatar
I have the RF in mine. Just pull the pillars off and unplug the tweeters. They come unclipped from the plactic pillar and then you just have to cut the grille out to the size of your new tweeters. Use a sharp knife and be carefull. Make sure you have a way to mount your new tweeters as well before cutting and messing up you pillars.
Old Jan 12, 2008 | 10:19 AM
stick's Avatar
Here are some pics I took of mine this morning.
These have a mounting ring behind the pillare panel that holds them in place and about five feet of wiring to run to your crossover. They don't quite follow the curve of the panel, but you'll never notice and probably never find ones that do anyway.
Old Jan 14, 2008 | 02:14 AM
quest51210's Avatar
you can mount them from behind as well
Old Feb 11, 2008 | 09:17 PM
ferrarimanf355's Avatar
stick, how big are your tweeters? 1/2"? 3/4"? 1"?
Old Feb 11, 2008 | 09:47 PM
stick's Avatar
3/4" Had to look at the box to know for sure.
Old Feb 13, 2008 | 04:04 PM
hugheshhr's Avatar
I mounted my exile tweeters behind the panel. You just have to be creative how to hold them in. We used zip ties screwed across the back of the tweeters like a strap. It worked.
hhrumadbruh
Apr 15, 2012 12:29 PM
hhrumadbruh
Apr 5, 2012 09:01 PM
Joshua022
Mar 29, 2012 11:59 AM
