How to pics
Old Apr 14, 2006 | 09:45 PM
KNEZRYD's Avatar
How to pics
Someone posted step by step pics of the lowering process but I can't seem to find them on here. Can anybody help me out, I plan on lowering it first thing tomorrow.
Old Apr 14, 2006 | 09:47 PM
captain howdy's Avatar
https://www.chevyhhr.net/forums/how-tutorial-library-21/spring-install-dial-up-enter-your-own-risk-986/
I think that's the one you want.
Old Apr 14, 2006 | 09:59 PM
KNEZRYD's Avatar
Thanks alot cap'n. That was exactly what I was looking for. I'll let everyone know how it goes later. Thanks again!
Old Apr 14, 2006 | 10:07 PM
HHR DLYT's Avatar
Kenny, make sure you post some pix for us. Before and after would be great!
Old Apr 14, 2006 | 10:10 PM
ng8650's Avatar
Someone recently cut the wrong end of the bumpstop. If you're not sure, use SoCal's bumpstop how-to. In order to get a bumpstop from the dealer, you have to buy the whole spring assy. Or you have to find one in the junker...
Ng
Old Apr 14, 2006 | 10:43 PM
cjnappo's Avatar
that was me im an idiot but i finally found a set of bump stops at a junk yard in new york cost me 30 should be here mon or tues
Old Apr 14, 2006 | 10:46 PM
ng8650's Avatar
Are you going to cut them? Or are you going to try them stock? I remember another owner recommending leaving them stock.
Ng
Old Apr 14, 2006 | 11:15 PM
crowbar's Avatar
i think he has already rolled his fenders, uncut bumpstops wont be any good
had my fenders grinded down today no more rubbing
Old Apr 15, 2006 | 12:12 AM
hvrod's Avatar
ahhhh another customer with rubbing issues..
basically your bottoming out on the 1 to 1 1/2 inch gap left for the shock to absorb any deviations in road variations...
Old Apr 15, 2006 | 01:07 AM
SoCalHHR's Avatar
If you read his earlier posts he has no "bottoming" problems. The only rubbing issues are for owners running rims wider than 8" - or the wrong offset. HHR's are rubbing the insides of the rear fender lips with wider rims.
The HHR was designed for 7-inch wide rims, with a 42mm offset.
Most other lowered FWD cars must undergo the same mods to run wider wheels - or other offsets.
