Stock Radio Pinouts
Old Nov 11, 2008 | 09:35 AM
mchuntley's Avatar
Stock Radio Pinouts
Does anyone have the pinouts to the back of the stock radio, and then next model up of the radio?
I have a mod I am considering.
Thanks,
Matt
Old Nov 11, 2008 | 09:46 AM
ChevyMgr's Avatar
Are you wanting the wire harness pinouts? I can post them but I need to know what radio RPO code you have and what RPO code you want to install.
Old Nov 11, 2008 | 10:23 AM
mchuntley's Avatar
Good Question, let me look it up
Old Nov 11, 2008 | 07:58 PM
mchuntley's Avatar
Are these the codes you were looking for?:
UW5 - 6 SPEAKER SYSTEM
U1C - AM/FM STEREO RADIO/COMPACT DISC ELECTRONICALLY TUNED AM/FM STEREO RADIO W/SEEK,TONE SELECT, COMPACT DISC PLAYER, DIGITAL CLOCK AND 4 SPEAKERS
Old Nov 13, 2008 | 05:42 PM
ChevyMgr's Avatar
Here are both connectors for the UW5 radio.
Radio C1 (UW5)
Pin-Wire-Color-Circuit No.-Function
1-RD/WH-1140-Battery Positive Voltage
2-GY-8-Instrument Panel Lamp Dimmer Switch Signal
3----Not Used
4-DGN-117-Right Front Speaker Output (-)
5-LGN-200-Right Front Speaker Output (+)
6-GY-118-Left Front Speaker Output (-)
7-TN-201-Left Front Speaker Output (+)
8-BK/WH-651-Ground
9-DGN-5060-Low Speed GMLAN Serial Data (Early Production)
D-GN/WH-5060-Low Speed GMLAN Serial Data (Late Production)
10---- Not Used
11-DBU-1796-Steering Wheel Control Signal (UK3)
12-14----Not Used
Radio C2 (UW5)
Pin-Wire Color-Circuit No.-Function
1-BN/WH 367-Remote Radio Left Audio Signal (+) (U2K)
2-DGN/WH-368-Remote Radio Right Audio Signal (+) (U2K)
3-PK-314-Radio On Signal
4-DBU-46-Right Rear Speaker Output (+)
5-LBU-115-Right Rear Speaker Output (-)
6-BN-199-Left Rear Speaker Output (+)
7-YE-116-Left Rear Speaker Output (-)
8-PK/BK-2062-Cellular Telephone Voice Signal (UE1)
9-TN/WH-372-Audio Common (U2K)
10-13----Not Used
14-WH/BK-644-10 Volt Reference (UK3)
15----Not Used
16-OG/BK-2061-Cellular Telephone Voice Low Reference (UE1)
Old Nov 13, 2008 | 11:09 PM
mchuntley's Avatar
Hmmm
That sounds like an input to the stereo, I guess the common/ground is the third line... So the base radio does have inputs on the back for another device.
I feel the need to tinker...
Old Nov 13, 2008 | 11:15 PM
mchuntley's Avatar
Oh, drat
And Thank You Very Much
Old Nov 26, 2008 | 12:31 PM
prod's Avatar
Originally Posted by mchuntley
Hmmm
Oh, drat
Did I miss something? These are probably for onstar, right?
Old Nov 26, 2008 | 12:38 PM
ChevyMgr's Avatar
U2K is XM radio.
Old Nov 26, 2008 | 12:45 PM
prod's Avatar
U2K is XM radio.
Cool, do you know if these can be used to wire in an audio device kept in the top storage bin?
