Where to catch pink remote wire?
Old Dec 9, 2008 | 11:27 AM
prod's Avatar
Its really cold here, I dont want to try pulling the HU for fear of snapping something in half. Does anyone know the routing of the pink #8 wire after coming off the radio connector? Im hoping to catch it under the dash somewhere, but it seems pretty well hidden.
Old Dec 9, 2008 | 11:55 AM
djmoose's Avatar
You can see it very easilly in the fuse area on the passenger side of the main console. (where all the fuses are inside the car)
Old Dec 9, 2008 | 11:58 AM
prod's Avatar
Isnt that a thicker wire for something else? I assumed the one off the radio was fairly thin.
Old Dec 9, 2008 | 12:25 PM
djmoose's Avatar
Yes, the thicker one. It's the one I used and I also tested it with a DMM. It's 12V+ when ign is on and grounded when ign is off.
Old Dec 9, 2008 | 10:35 PM
masterchief1112's Avatar
remote wire as in for amp correct. just clarifying because im installing an amp and woofer and was wondering where to grab this
Old Dec 10, 2008 | 07:38 PM
djmoose's Avatar
I'm not sure you should be using the pink ign wire as the remote for your amps...I'm guessing it should work...
I was just helping locate the ign wire. lol!
Old Dec 10, 2008 | 09:32 PM
Rcflyboy's Avatar
I would take the HU out myself. Only a cover and 6 screws. Very simple. Far easier to get the wire you want without making a mistake.
tahenke
Aug 26, 2018 03:14 PM
sttcharl
Nov 21, 2010 04:07 PM
lefthandedrighty
Nov 24, 2009 12:13 PM
keverz146
Mar 12, 2007 10:56 PM
wowzer
Jun 24, 2006 10:08 PM
