gain on factory amp...
Old Jan 9, 2009 | 10:34 AM
badboy69's Avatar
is there a way to up the gain on the factory sub amp... I find that the base is not high enough
Old Jan 9, 2009 | 10:56 AM
ChevyMgr's Avatar
You could always go this route.
https://www.chevyhhr.net/forums/audio-video-17/08-world-finals-install-20551/
Old Jan 9, 2009 | 11:16 AM
Ed RazorLite's Avatar
lol, thanks, that is a good way to go if I do say so myself.
But there is no way you can turn the gain up on the factory amp. It is set at the factory to work well with the factory sub.
Even if you could turn it up, it would most likely blow the sub.
Best bet is an aftermarket amp and sub.
You cav do a single ten and a small 600w amp and get much better response than the factory sub
hhrumadbruh
Jun 7, 2013 08:58 PM
goetylsd
18
Jul 24, 2010 03:20 PM
Littlemanhhr
2.4L Performance Tech
23
Oct 1, 2009 11:37 PM
