USB Fail
Old Aug 25, 2009 | 02:53 PM
RoSSpert's Avatar
USB Fail
Alright so I have a 4gb usb stick formatted fat32, with mp3s on it, when I plug into the port on the radio it keeps saying device load fail or something like that. Anyone know how to correct this, I tried searching on here but I must be search retarded. Thanks in advance.
Micky
Old Aug 25, 2009 | 03:02 PM
ChevyMgr's Avatar
Try another brand of memory stick to make sure the radio is reading it.
Old Aug 25, 2009 | 03:36 PM
oneton's Avatar
Look Here https://www.chevyhhr.net/forums/problems-service-repairs-42/usb-issue-25304/
Old Aug 25, 2009 | 04:52 PM
RoSSpert's Avatar
I have a usb sd card reader that I tried and that works fine reading mp3s off the sd card. The one I have that doesnt work is a sandisk cruzer 4 gb just so you guys know. Thanks
Micky
Old Aug 25, 2009 | 07:29 PM
HHRSSouth's Avatar
I'm using a cheap Lexar USB stick (made in china unfortunately), but it works flawlessly.
Old Aug 27, 2009 | 03:57 PM
Dremin2flyhi's Avatar
If it is a Ready Boost USB stick with the U3 software on it -- it maybe seen as 2 different drives-- although you only have the one usb stick in-- this will confuse the radio sometimes as it will mount the U3 software drive instead of the MP3 part of the USB stick causing it not to load properly. I ran into the same issue with a CNC machine the other day. Try plugging it into an XP machine and go to my computer and see if 2 drives are being mounted when the stick is being plugged in.
SMH2010SSHHR
Feb 13, 2022 09:58 AM
Lucky
Dec 31, 2013 10:28 AM
Gagarin
Nov 18, 2009 07:47 PM
SandyBeach
Dec 29, 2008 07:24 PM
Kennys2009HHR
Aug 2, 2008 10:06 AM
