08 HHR radio swap.
Old Sep 4, 2009 | 06:30 PM
hanjin's Avatar
08 HHR radio swap.
Greetings! I recently purchased an 08 HHR panel, and I can't seem to find out some info on swaping out the radio. The car currently has the U1C radio and I wanted to swap it for the US9 6 disc cd radio from another HHR. Can this be done? Thanks in advance.
Hanjin
Old Sep 4, 2009 | 06:47 PM
ChevyMgr's Avatar
Yes, but you will have to take it to the dealer to be programmed.
Old Sep 4, 2009 | 06:49 PM
hanjin's Avatar
Sweet! Thanks for the quick reply.
Old Sep 5, 2009 | 12:16 AM
prod's Avatar
Is the wiring the same? Just pull the two plugs and antenna and plug them into the new one? And isnt the 6cd any bigger? There isnt really any extra room in there with just the base stereo.
Old Sep 5, 2009 | 05:40 AM
courthousedeb's Avatar
Back in 2006, I swapped out my one disc for a 6 disc and they swapped out with no fitment issues at all...it was a piece of cake. Unplug old one...plug new one into same plugs. Much to my surprise, the new one wouldn't work until I took it to the dealer to have it programmed...and was charged me $89 for doing it. You might want to call and see what, if anything they will charge you...before you do it, so there aren't any surprises.
Old Sep 5, 2009 | 11:25 AM
Sno White's Avatar
X2
My type of advise.
Old Sep 11, 2009 | 06:45 PM
hanjin's Avatar
Now here is the twist. The radio I have is from a Tahoe, will this still owrk in the HHR, or are the rear plugs different?
Old Sep 11, 2009 | 07:36 PM
ohnomobile's Avatar
Just a quick idea....Some dealers use outside stereo / repair shops....They might be able to tell you.... Plus they have the code's or can obtain them from the dealers they do work for....Good luck
Old Sep 19, 2009 | 03:05 AM
jerseymike68's Avatar
thanks for this idea
KJT
Aug 18, 2015 10:09 PM
DBHHRLT
2.4L Performance Tech
Oct 20, 2014 05:41 AM
lgn6969
Jul 10, 2012 11:46 PM
08 hhr guy
Dec 6, 2010 10:16 AM
