Factory 7-speaker system question
Old Jan 2, 2010 | 10:27 AM
hatetoorun's Avatar
So I am swaping out everything from front to back. I do not know much about our HHRs yet and I can't seem to find what I'm looking for in the search bar.
How many amps does my car have? If it's one, is it a 5-channel? Or does the headunit power the doors/tweeters and a 1-channel amp power the subwoofer?
Old Jan 2, 2010 | 10:52 AM
The sub does have it's own amp.
Old Jan 2, 2010 | 11:07 AM
hatetoorun's Avatar
How are the door speakers and tweeters powered, external amp or by the headunit?
Old Jan 2, 2010 | 11:39 AM
prod's Avatar
Actually the amp mounted to the sub box is 5channel and powers the doors and sub.
Old Jan 2, 2010 | 12:32 PM
hatetoorun's Avatar
Great thanks. That was exactly what I needed to know.
Where are you splicing into the factory harness for the door speakers?
I'm thinking I'm just going to hook the door speakers to the headunit and run the 8inch sub off a small mono-amp like the Alpine MRP-M500 or something similar.
Old Jan 2, 2010 | 05:02 PM
hatetoorun's Avatar
Ok so I went to talk with the installers at Best Buy. From what I got from them is the LAN-04 will integrate my new Alpine to my factory amp. Will I lose sound quality that my Alpine would be putting out? Can I still use the equalizer on the new headunit to its full ability?
Or am I better off bypassing the factory amp all together?
Old Jan 2, 2010 | 05:53 PM
prod's Avatar
Are you talking alpine amp or head unit?
I thought you were swapping everything out. If so, the factory amp really isnt worth keeping, its only about 25w per speaker.
Old Jan 2, 2010 | 06:03 PM
hatetoorun's Avatar
From the info you told me about the factory amp, I am going to bypass it all together and just use the Alpine headunit to power my door speakers.
I am assuming bypassing the factory amp is easy? any input would be great.
I already have the GMOS-LAN-04. It is ment to integrate the factory amp. Can I still use this harness if I plan on bypassing the factory amp?
3800seriesII
Nov 28, 2014 12:24 AM
PFSHHRSS
Jul 3, 2008 09:41 AM
MOTRV8D
Mar 2, 2008 08:21 PM
lilturk1
Jul 3, 2006 01:02 PM
DigitizedLife
Feb 10, 2006 05:42 AM
