Will PAC AOEM-GM1416a work on 2009?
Old Feb 3, 2010 | 02:51 PM
pnad's Avatar
Their site lists 2006-2008 HHR
http://www.autosoundcentral.com/PAC_...oemgm1416a.htm
Anyone use this on a 2009? I'm doubting much changed from 08 to 09 but you never know.
Old Feb 4, 2010 | 11:16 AM
pnad's Avatar
The reply from AutoSound is a little limp
From: AutoSound Central [mailto:autosoundcentral@sbcglobal.net]
Sent: Thursday, February 04, 2010 11:06 AM
Subject: Re: PAC AOEM-GM1416a GM Add an Amplifier Adapter
Hello,
The connectors are the same so it should work. Thanks Steve
Old Feb 7, 2012 | 03:43 AM
yur_maker's Avatar
According to this site it will work if you have standard 11 bit Radio with 14 or 16 pins.
http://replacementradios.com/product...oducts_id=1505
I just purchase one for my 2010 HHR LT with radio 1 step down from premium no factory sub, XM disabled.
Also purchased JL2 500.1 mono block amp and 2 JL 10WX 10" 4ohm subs in sealed boxes.
I'm going to install the amp in the spot where the stock sub would be and put a connector plate in the side molding Speakon connectors, so if i want to remove the subs its simply unplug the boxes.
Old Feb 10, 2012 | 05:16 PM
otacon's Avatar
Good info I have a 2011 LS with 1 step down from premium as well. I have XM and Onstar so I really don't want to replace the factory radio. Been wanting to put a sub in this thing for a while..lol
Old Feb 18, 2012 | 05:56 AM
pnad's Avatar
FYI, I put a 12" sub in the HHR back in '10 and it still sounds fantastic.
gazar53
May 20, 2015 06:00 AM
Jeffharden1
Aug 25, 2014 01:50 PM
evowake
Jun 11, 2012 08:50 AM
GDZHHR
Dec 7, 2008 05:23 PM
terry44030
Mid East
May 25, 2007 04:43 PM
