back seat amp?
Old Dec 11, 2010 | 06:36 PM
Malanchi's Avatar
back seat amp?
just curios if anybody has removed the rear seats in there HHR and if soo is there enough room underneath that back seat to shove a amp under there and put the seat on top of it?
Old Dec 11, 2010 | 06:46 PM
Might be a better place for an amp in the storage/spare tire well or tucked in one of the rear quarters. I think its pretty tight under the seat if memory serves me right.
Old Dec 11, 2010 | 06:53 PM
Malanchi's Avatar
yea just trying to make everything as "stealth" as possible without taking up to much cargo space and im trying to avoid too much cutting and trimming.. reason being i work in new Orleans.
Old Dec 11, 2010 | 07:06 PM
Do you have the premium sound with the factory sub woofer? If you don't there is a tailor made spot in the left rear quarter where the factory sub and amp go. It should be nothing but empty space if you don't have that option.
Old Dec 11, 2010 | 07:17 PM
Malanchi's Avatar
i knew about that empty space . but i couldn't find any internet links on how i could remove that back left panel if you know how or have a link could you share it?
Old Dec 11, 2010 | 09:00 PM
I'm away from my office computer right now, but I'll try and PM you a PDF of the section of the shop manual you'll need. Should be able to get that to you tomorrow afternoon when I'm back in Charlotte if that works. Maybe somebody here can link you up before then.
Old Dec 12, 2010 | 12:00 AM
Check your e-mail, hope this helps you out.
Old Dec 19, 2010 | 05:18 AM
bugflipper's Avatar
There is plenty of room under the rear seat. You don't have to take it out. Just remove the plastic thing with two storage compartments that is directly behind it. This allows access to under the seat. Also the rear wall of where the tire is next to the battery. Just unsnap the plastic piece where the bottom of the rear gate would shut to gain better access for installation.
rbmount
Dec 28, 2014 01:41 PM
2003_2LT
Apr 13, 2013 10:55 PM
jpaulabbott
Maintenance and Upkeep
0
May 24, 2011 10:40 PM
sargechris
Jan 4, 2009 06:20 PM
ugly dave
Jun 14, 2008 03:54 PM
