2 way or 3 way
Old Jun 4, 2011 | 02:57 PM
lucasbuck's Avatar
2 way or 3 way
I was wondering for the door speakers. Since there's already tweeters in the pillars, would a 3 way in the door throw it off and make to much high end? Thanks for any advice.
Old Jun 4, 2011 | 03:37 PM
I think you'd find that the sound would be a bit too "bright" with a surplus of tweeters, but that's just my humble opinion. I'm sure the folks with the gazillion watt systems will chime in with advice on this.
Old Jun 4, 2011 | 03:40 PM
Zagohhr's Avatar
I would sugest you try with a component set (Tweteer, crossover & Mid bass). Factory tweeters are a little crappy...
Old Jun 5, 2011 | 12:30 AM
prod's Avatar
I have 3way in the doors, I just disconnected the pillar tweeters. They get rough at high volume.
Also its better to have tweeters near the mids for correct imaging.
Old Jun 5, 2011 | 03:12 PM
lucasbuck's Avatar
Thanks for the replies. How do you go about unhooking the pillars?
Old Jun 6, 2011 | 12:14 AM
prod's Avatar
Its pretty easy, just take the pillar top torx screw out, then pull the bottom up and out. You should be able to unplug the wire then.
Old Jun 6, 2011 | 12:16 AM
Eric B's Avatar
I love 3-ways when properly setup.
Old Jun 10, 2011 | 08:12 PM
ATLsilverSS's Avatar
correct but your staging needs to be at ear level which is why people started putting tweeters in the pillars. with good staging you can overcome the tweeter driver separation
Old Jun 11, 2011 | 06:26 AM
08bowtie's Avatar
re
havent had 3 ways in a while....got married - stuck with 2 way
