Stock Speaker Impedance?
Old Jan 7, 2012 | 03:56 PM
Kevin3492's Avatar
Question Stock Speaker Impedance?
For those who have replaced the speakers in an "upgraded Pioneer" system, what is the impedance of the stock units? 2 Ohms, 4 Ohms...
Thanks for the help!
Kevin
Old Jan 7, 2012 | 05:07 PM
Originally posted by Prod......
"On the base system, the front door speakers are 4ohm and the rear door speakers are 8ohm. I believe on the uplevel pioneer system, all are 2ohm."
Old Jan 7, 2012 | 10:01 PM
ebritt's Avatar
The stock units "impede" my audio enjoyment!! LOL, sorry, that just slipped out....
Old Jan 7, 2012 | 11:57 PM
prod's Avatar
hey, thats me!
I have the base system, so you should verify the 2ohm statement with someone who has worked on it. I read it on here somewhere.
Old Jan 12, 2012 | 03:33 AM
bugflipper's Avatar
Premium is 2 ohm for sure. If you replace them you can get a set of 4 ohm with higher sensitivity and retain the volume level. Just not that many 2 ohm aftermarket speakers. Infinity makes some, but they are harsh and for the price there are far better sounding ones.
2 ohm is double the wattage as 4 ohm. The stock speakers are 84 db sensitivity. So look for a set of 4 ohm with 90 db sensitivity or higher and you will not loose any volume. Just for reference a 6db gain is equal to double the wattage. Double the wattage is a 60% gain in actual volume. Decrease the wattage by half you loose 6db by going to 4 ohm. Increase sensitivity to 90 db for a 6 db gain over stock and you are back even with the output of the 2 ohm speaker in perceived volume.
Old Jan 12, 2012 | 11:09 AM
Kevin3492's Avatar
Thumbs up Thanks bigflipper!
Thanks bugflipper, I really appreciate the 2 ohm confirmation. The additional sensitivity information is also appreciated.
Last edited by Kevin3492; Jan 13, 2012 at 09:26 AM. Reason: conformation?? What a maroon!
Old Jan 12, 2012 | 02:12 PM
07azhhr's Avatar
I measured 2.7 ohms on mine. I would think that makes these more likely to be 3 ohm. The sub is dual 2 ohm ran in 2 ohm stereo mode at the amp.
Old Jan 17, 2012 | 01:39 PM
barfan1's Avatar
I have new speakers and adapter harnesses ready to install, I just want to have a definite answer before I jump in-I have the Pioneer upgraded system-Do I need the adapter rings for the speakers or will they bolt right in? I know the base level system needs them but I couldn't find a definite answer about the Pioneer system.
Old Jan 18, 2012 | 03:13 PM
07azhhr's Avatar
That will depend on your speakers going in. I have not replaced my factory (amplified speakers) yet but when I took them out to look at them and the hole it looked like a standard size 6.5". But every brand of speakers is different so without knowing what ones you bought then no one will be able to tell you yes or no. I can tell you that there is plenty of room infront of the factory speakers to be able to use speaker spacer rings without hitting the interior panel.
Old Jan 23, 2012 | 06:15 AM
SpaceCowboy's Avatar
I haven't had my doors apart yet but I have worked on other GM products that need some adapters for the best fit like these http://www.sonicelectronix.com/item_...AGMHR634B.html
Scosche SAGMHR634B
HHRthunder13
Sep 16, 2018 10:32 AM
Bigpatshhr
Jan 29, 2015 07:59 AM
blizzard
Jan 17, 2013 06:34 PM
STLracerX
Aug 5, 2009 06:30 PM
