Lowest static drop
Old Jan 10, 2012 | 01:02 PM
Turbo Hearse's Avatar
Lowest static drop
So who has the lowest hhr on here? Or anyone have pics of some slammed hhrs that aren't bagged?
Old Jan 10, 2012 | 02:24 PM
That takes bags to do. Lunchbox, Garage built. Look them up they have pics in their gallery's. I put the pedders on it looked good, but I was giving up the awesome performance, so I switched them back and put bigger tires an wheels on. with and with out.
Old Jan 10, 2012 | 03:20 PM
What takes bags to do? I asked who has the lowest static drop. Not bagged
Old Jan 10, 2012 | 05:17 PM
capp002's Avatar
you be the judge CALLING ALL LOWERED HHRS LOOOOOL
Old Jan 10, 2012 | 05:45 PM
I thought you said slammed heres one, or two coil overs will get you the closest to the ground. Aaron is trying to sell some here https://www.chevyhhr.net/forums/show...ght=coil+overs
Old Jan 10, 2012 | 05:58 PM
peevlos's Avatar
if u count coilovers check out his ride
https://www.chevyhhr.net/forums/show...ight=coilovers
Old Jan 10, 2012 | 06:46 PM
tmerkle111's Avatar
Hi, I'm a little confused on this. How did you lose performance on a lowered car that is front wheel drive? I would think you would gain, because the aerodynamics would be better and less body roll. I would also think that bigger tires and wheels would add more weight to cause loss of performance. Could you tell me how you were giving up performance?
Thanks,
Tom
Old Jan 11, 2012 | 06:18 AM
Blue_SS's Avatar
^ I'm going to guess that it f-ed up the front end geometry. Less travel can do that, but it also could have just been a harsher ride. Coming from the WRX world, I can say that MANY people who slam their cars reduce performance when they do so.
Old Jan 11, 2012 | 08:04 AM
Guess you had to be here. I put them in, drove the car a couple days, that's about as long as I can do that teeny bounce.I was scared it would do that going around a corner, that had a little bump in it. You probably won't believe that the TTR swaybar was contributing to the pushing in the corners either. I was amazed when I took it off, try it. I was even more amazed when I installed the Powell, "Moon" was right about that, I don't have body roll, and I do have travel. I've had it come off the ground going around a corner without a problem, GM made a good set of springs fe5's, I'm a fan.
The new tire & wheel is a tad lighter, but wow what a smooth ride.
Hey, Capp panel looks great, nice wheels.
I wanted to add, if you are running on a track, Pedders will be fine, they do lower your center. I just don't think they do the bumps, of normal roads well, make sense now ?
Old Jan 11, 2012 | 08:52 AM
tmerkle111's Avatar
Thanks for replying. If I am understanding you correctly it basically gave you a horrible ride, which would cause you to not push the car has hard as you would like to because it didn't seem stable. Also you are saying that you would get rid of the TTR and get the Powell bar instead. Just curious because I would rather not lower the car if it causes problems. Only reason why I am asking. Just don't want to waste money on something that isn't needed. Thanks again.
