the ultimate rotor fix
when I say ultimate..I meant anythin would be better than stock junk...these are a Canadian made product right here in Toronto Ontario..no sense in payn shippn charges when this manufac plant is right in my backyard..quality right on par with other high end rotorshttp://www.marcor.ca/home/msport/msport-rotors-about
Rotors
I have some rotors on my pickup that you may be interested in. I had a set of cross drilled, slotted rotors by Baer and they said they wouldn't warp. So much b/s. I found a website you should look into, go here: FrozenRotors.com I am sold on these rotors. If they can stop my SVT Lightning at 150mph with constant braking, they're worth the investment. They have crossdrilled slotted and slotted only for the HHR.
DMarotta
Dec 2, 2014 10:24 PM
[/IMG]chuk the old junk...replace with the good stuff
