HHR Front Suspension ????'s
Old Sep 19, 2012 | 10:10 PM
afornal's Avatar
Exclamation HHR Front Suspension ????'s
Hello everyone - Let me intro myself. NEW Here to the forum. I just purchased a 2008 Chevy HHR Flash Blue 4dr. Can anyone point me to any info on the front suspension? Any issues with them? Not sure I want to ask.....Any Ball Joint issues with this vehicle? Looking for some tru feedback, then I'll tell ya and show ya my experience with this 08 HHR.....Thanks look forwrd to hearing from ya'll.......Andrew
Old Sep 19, 2012 | 10:26 PM
murdog94's Avatar
The struts wear out like any other car, and from what i have seen the sway bar end links like to go bad, but otherwise it doesnt have that many issues. Really it is a well built car.
Old Sep 19, 2012 | 10:49 PM
Welcome Andrew, if you want to avoid the normal issues with the front suspension, just switch your sway bar links to grease-able moogs, and the bar bushings to energy suspension grease-able poly, and you will just skip the issues.
Old Sep 20, 2012 | 12:17 AM
Silverfox's Avatar
Any re-front end alignment required with replacement of these parts?
Old Sep 20, 2012 | 03:31 AM
jaytheredneck1's Avatar
Not typically with sway bar links or bushings.
Old Sep 20, 2012 | 10:07 AM
@afornal, check out the Owner's Center site at my.chevrolet.com. You will have access to many things such as owner's manual, various manuals, videos and things of that nature.
Welcome to the forum!!!!!
Old Sep 20, 2012 | 12:28 PM
geg's Avatar
geg
Just by the way ..
Eighteen months ago, I used the stabilizer links from Toyota Camry. Past weekend - big inspection of suspension in preparation for winter. Links look cheerfully, no signs of fatigue. GM links die more often.
Do your findings.
Old Sep 20, 2012 | 11:33 PM
murdog94's Avatar
Originally Posted by geg
Just by the way ..
Do your findings.
Now that is awesome. i didnt know they would convert.
Old Sep 21, 2012 | 04:20 AM
geg's Avatar
geg
it is here
https://www.chevyhhr.net/forums/show...7&postcount=45
By the way, please forgive me for the inaccuracy. It took 14 months, not 18.
But the result is still very good. Perhaps it's because Toyota Camry - more weight and used for this purpose more powered links.
PS Imagine how much GM earns an annual replacement of links to all of its cars. That millions, just use a little less strong iron, a little more liquid lubricant.
Old Sep 21, 2012 | 11:05 AM
IgottaWoody's Avatar
They appear to be identical! 10mm isnt enough to worry about..
