wireless back up cam install
Old Nov 20, 2012 | 11:25 AM
fredygarvin's Avatar
I have a pyle pldn74bti head unit and i added a wireless backup cam. Works great in camera mode but how do i wire the receiver to turn on when i put the car in reverse?
Old Nov 20, 2012 | 12:04 PM
skyline26's Avatar
tap it in to your reverse lights
Old Nov 20, 2012 | 12:15 PM
Anywhere up front to do that?
Old Nov 20, 2012 | 01:21 PM
Check fuse #46 in the engine compartment fuse block.
Old Nov 20, 2012 | 02:06 PM
Felony's Avatar
The reverse switch is sitting on top of the tranny under the hood. You can run a wire through the firewall. Easier access by removing the LF wheel.
Old Nov 20, 2012 | 04:32 PM
Since the transmitter is connected to reverse light, can i just connect the reverse wire from the head unit to the camera receive?
Old Nov 20, 2012 | 05:18 PM
Not sure exactly how the set up is wired. The question would be how many amps each requires. Don't want to overload that fuse by hooking up too many extras.
Old Dec 2, 2012 | 06:42 PM
hhrumadbruh's Avatar
That's what it's for, afterall.
Test it with a voltage meter to make sure it's getting power when the car is in reverse
oldracer
May 8, 2013 08:03 AM
wolfee
Jul 9, 2010 09:26 PM
mrjuma
Oct 12, 2008 11:18 AM
JimZ_HHR
Jul 28, 2007 04:06 AM
SIHHR
Dec 6, 2005 10:32 AM
