FYI Lowered w/ aftermarket struts
Old Mar 31, 2013 | 06:23 PM
IgottaWoody's Avatar
Found out over this weekend that if you changed out your struts and are lowered,,AND need to use camber bolts, that some of the struts are NOT set up for this like the stock units are. The stockers are slotted while the aftermarket ones are straight drilled..so if you have replaced struts and the alignment guy says he has to grind out the strut to get back in alignment, you now know why....
Old Mar 31, 2013 | 06:52 PM
I took it for granted that was a common proceedure, but I do my own work so, now that you mention it , that statement from the alignment shop would seem scary!!Thanks
Old Apr 1, 2013 | 01:10 PM
jay loukakis's Avatar
2 years ago I had alighnment done they had to order 2 smaller bolts from Nappa $40.00 this is the 2nd car that had to have smaller bolts to align. with the struts.
dgrabes
21
Feb 8, 2013 12:44 PM
AllEyezOnMe
7
Feb 11, 2009 08:19 AM
xzombiex66
28
Sep 2, 2008 09:53 PM
elliot
Dec 18, 2006 06:04 PM
JOEK86
30
Aug 23, 2006 07:57 AM
