Direct Wiring for 2006 HHR with 7 speaker system and Amp
Old Jan 30, 2006 | 09:47 PM
DigitizedLife's Avatar
Junior Member
(for those who choose to keep the factory amp and change the head unit)
(or those who wish to use the factory amp with a carputer)
[Harness 1]
Battery(+) = [RED/WHITE]
Ground(-) = [BLACK/WHITE]
Left Front Low Level = [DARK-GREEN(-)] [TAN(+)]
Right Front Low Level = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)]
[Harness 2]
Amp Turn On Signal (same as power antenna) = [PINK]
Left Rear Low Level = [BROWN(-)] [BROWN/WHITE(+)]
Right Rear Low Level = [TAN(-)] [DARK-BLUE(+)]
The ignition line will have to be sourced elsewhere
as it is controlled by the GMLAN.
Check the fuse panel to the right of the center console for a source.
[Hint](Power windows work after you shut off your car, until you open a door!)
Old Jan 30, 2006 | 10:13 PM
snova031's Avatar
[Harness 1]
[Harness 2]
Power windows are retained accessory, which is probably interlaced with the dome supervision...that's not a wire you're going to want to jump. The BCM is in the same panel as the fusepanel...you can grab the main accessory wire from the BCM- that's going to be your best bet.
You can also grab accessory at the ignition harness
It's the brown wire there
Old Feb 10, 2006 | 05:42 AM
monster5601's Avatar
[Harness 1]
[Harness 2]
To enhance your work, here are pictures of all the audio connectors and pin outs.
http://n8zcc.com/pics/HHR/Audio_Connectors.pdf
akleiner92
May 19, 2013 04:31 PM
Lee3333
Mar 13, 2008 08:59 AM
MOTRV8D
Mar 2, 2008 08:21 PM
JimZ_HHR
Nov 24, 2006 10:58 AM
lilturk1
Jul 3, 2006 01:02 PM
