08 SS falling on its face
Old May 4, 2012 | 04:29 AM
Amir's Avatar
I need some help. Im new to the turbo world but excited to be here. I had my ss tuned at zzp and after about two weeks the car started falling on its face during acceleration. There are no service engine lights and as long as i stay out of boost it drives nice. But as soon as that needle passes 0 it starts falling hard. I was thinking it could be the stock bypass valve failing but I am not sure. Your thoughts please and thank you.
Old May 4, 2012 | 06:12 AM
08SSREDHHR's Avatar
My best advice would be to contact ZZP, could be the tune. Just ask them what they think.
Old May 4, 2012 | 09:34 AM
foolmoon_design's Avatar
After vac, no pressure..... You my friend have a very bad leak. I would look for a tear, or busted end tank.
Old May 4, 2012 | 10:14 AM
X2 on what foolmoon says.Check the system for a leak.
Old May 4, 2012 | 10:23 AM
XtremeSS's Avatar
the only time my ss ever "falls on its face" is when my drop-in k&n air filter comes off which only happened a couple times. If you have no leaks i would check your BPV or mabe the MAF needs calibration.
Old May 5, 2012 | 06:25 AM
Amir's Avatar
thankyou
thank you all very much this is a big help.
larryv
Jul 14, 2014 06:31 AM
jeffro
Jun 27, 2010 09:53 PM
catdaddy137
Sep 13, 2009 12:29 PM
stephensj88
Jul 23, 2008 07:55 PM
Desert Coyote
Mar 18, 2007 10:25 PM
