'09 SS oil leak
Old Nov 9, 2010 | 04:33 PM
pitbull76's Avatar
A dealer *might* know of some common leak spots on this engine better than an independant mechanic but will probably charge more for a diagnosis. For the cost of the repair, maybe you ought to check with both? I also wonder if anyone here has experience with a good shop(or dealer) in your area. Wouldn't hurt to ask in the general problems forum so you can hear from non-ss owners too.
Old Nov 9, 2010 | 04:52 PM
If it "looks wet" near the filter cap I wonder if it's just a bad o-ring..... It may not have been replaced with the last oil change (many of the filters come with a new o-ring, some don't)
Old Nov 10, 2010 | 07:50 AM
wraunch's Avatar
Yeah I am a bit skeptical. Supposedly the engine tech was busy all day but came over for a few minutes and saw where oil looked like it was "seeping" from the engine block near the oil filter. They said they wont know for sure until I bring it back so the engine tech can call the "technical advisors" and go through the procedure they give him to determine if it's the block.
Old Nov 12, 2010 | 02:33 AM
IgottaWoody's Avatar
Isnt this the same leak from the cam button..it runs down the end of the head and makes the filter look like its leaking?
Old Nov 12, 2010 | 07:59 AM
wraunch's Avatar
Hmm, I hadn't heard of that but that could be exactly it. What's the fix?
Old Nov 15, 2010 | 01:21 PM
  #26
wraunch's Avatar
Ok, so my non-dealer mechanic has looked at the leak and says he too thinks it might be a porous block. He said oil is seeping right above where the oil filter sets. He checked the cam plug and there was no leak present there. So, I will take it back to the dealer on Wednesday so they can do the definitive tests that will tell me if it is truly a porous block.
If it is and I can find where it is leaking, does anyone recommend me trying to find some kind of sealer before I break the bank and have a whole new engine installed? If I have to get an engine where is the best place to get a good buy on one?
Old Nov 15, 2010 | 01:32 PM
  #27
pitbull76's Avatar
There's used salvage motors listed on car-part.com Maybe you'll be lucky and one is close to you, but it doesn't look like it.
Old Nov 16, 2010 | 09:46 AM
  #28
wraunch's Avatar
Yeah I'm going to look. Also, what should I do with the old engine if I do take it out? I assume the components inside of it are in great condition as the car only has 36k miles on it.
Old Nov 17, 2010 | 12:24 AM
  #29
Make for a great blender motor for those tailgate parties!!
Old Nov 17, 2010 | 12:45 AM
  #30
http://search.eastwood.com/search?w=...FRJS2godeQ7AHA
Been using Glyptal in (alloy) Harley Motors since the late 70's..
