2008 HHR SS power lag
Old Jan 22, 2016 | 07:40 AM
  #31
And the code can cause limp mode!!!
Old Jan 22, 2016 | 09:30 AM
  #32
DrLoch's Avatar
To me it sounds like you may have 2 seperate problems. Replace the thermostat with an AC Delco one. Off brand thermostats have been known to cause problems before in the HHR's.
I agree. Fix the stat first. When hitting the throttle what is the RPM doing?
Old Jan 22, 2016 | 11:14 AM
  #33
Cody26's Avatar
The rpm seems to be responding just fine my ss is stock besides exhaust so it's not like I'm racking 4 are 5 thousand rpm but just cruising around town that judges just fine
Old Jan 22, 2016 | 11:58 AM
  #34
Cody26's Avatar
I have never heard of limp mode I have heard of power reduction did it go into limp mode when my check engine light come on
Old Jan 22, 2016 | 02:02 PM
  #35
They're the same thing. "Limp" is kind of like a slang term.
Like: Limp home when you're hurt.
Old Jan 22, 2016 | 02:59 PM
  #36
Dbeluscak's Avatar
Limp mode refers to a display on the DIC. It will display; ENG PWR REDUCED
There are CELs that bring it up instantly. I can't confirm that 0128 does. If blue says so I'd have to agree. But, you're definitely not in limp mode with any kind of boost.
I have had the loss of power from my MAF CEL. The ECM will only allow 4-5 lbs. And it is very noticeable when trying to accelerate. But it's nothing like ENG PWR REDUCED. With that on the display, you're car will barely run allowing only RPMs under 2000 and no boost. Just enough to let you "limp" home.
Get your stat installed, if you're not "clutch savvy" I would suggest having it looked at by someone that you trust.
Old Jan 22, 2016 | 10:18 PM
  #37
barstowpo's Avatar
My freeway power issue was clutch slip.
Pa134539
25
Dec 31, 2014 12:30 AM
pitbull76
14
Mar 24, 2012 03:20 PM
Trukguy
2.0L Performance Tech
Dec 4, 2009 07:07 AM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
Stealth
Mar 1, 2008 05:08 PM
