2008 SS Timing Chain Time - GM or aftermarket?
Old Oct 10, 2019 | 06:55 PM
terryk's Avatar
Is the balance shaft kit the 9-4202S or 9-4202SX? I can't find a 9-4202SX.
On the Cloyes site they list both for the LNF. Look for some difference.
Nevermind, with or without gears.
Old Oct 10, 2019 | 07:15 PM
Which way did you turn the camshafts? If you turned them counter clockwise, of course there will be slack.
Old Oct 10, 2019 | 07:22 PM
terryk's Avatar
Clockwise.
Old Oct 10, 2019 | 07:32 PM
Timing chain kit 9-4201SA is the one for VVT engines includes the crank sprocket.
Balance shaft chain kit 9-4202SX doesn’t include the sprockets
Originally Posted by terryk
Clockwise.
Ok, then yeah, there's a problem.
Old Oct 10, 2019 | 07:45 PM
  #26
terryk's Avatar
Lol! Either way, gotta check.
Old Oct 11, 2019 | 12:34 PM
  #27
It’s a known issue trying to rotate the crankshaft counter clockwise, that causes problems with the guides and tensioner.
just don’t drive it until you do the work .
Old Oct 11, 2019 | 12:50 PM
  #28
terryk's Avatar
Thumbs up
Agreed. I shut it off running fine other than the rough idle and low vac. I am taking it apart now. It's ain't running until I am done. Once I get the front cover off I can rotate the crank to TDC and see just how far off it is. Parts are ordered. I found a used J-38122 balancer tool cheap. I know I can do the starter bump but it was cheap and makes the bolt torque + angle straight forward. I can always sell it when done but I usually hang on to special tools like that while I have the car.
Old Oct 11, 2019 | 11:35 PM
  #29
terryk's Avatar
For anyone looking to buy the improved upper guide bolt, the ZZP bolt is the Dorman 917-954. What's nice is that it can also be used where the bolt broke off in the head and can't be extracted. Thanks to Oldblue for mentioning it!
Old Nov 6, 2019 | 10:42 PM
  #30
terryk's Avatar
Thumbs up
Got the chains (et al) installed. It was pretty straightforward. While none of the guides were broken, the exhaust cam alone appears to have been 2 teeth off from my count. I marked where the indicators were and counted linked once I had the new chain in. The tensioner appeared fine but it was hard to say if it was really enough. Once I fired it up, it went into a smooth idle, no loping plenty of vacuum. Not sure what happened but it's fixed.
Took it out for a test drive, ran great, came back and noticed my fan wasn't on with the temps are 210 and/or with the AC on. The Tech 2 says it's commanding the fan but it's not working. Powered the fan directly and it runs. Probably the control module but I want to test it.
So, anyone have the wiring diagram for the SS fan? The docs floating around that claim they are for the SS fan aren't -they are for the 2.2/2.4L fan(s).
Nevermind. Found it, it's the module. What timing ...
Thanks everyone for you input. And yes, the factory chains and guides are marked Cloyes. With the strike, getting GM parts was a no-go so I just went with the Cloyes labelled stuff. I also did my sway bar bushings. Let's not do that again. I could do it faster now that I know the trick to getting the old ones out ...
